1-888-41LOGIC
Power Infrastructure
They say “Knowledge is Power.”
And knowledge about your power is essential if UPSyou want to keep your systems up, and your power costs low.
LogicMonitor will give you that knowledge. UPS systems, PDU’s, environmental monitors, even the power distribution systems in a blade chassis – LogicMonitor knows what to monitor, and when to alert you about issues that could adversely affect your uptime.
And LogicMonitor’s flexible trending and dashboards will let you follow how your usage changes over time – you’ll be able to correlate power draw with new systems coming on line or off line, or increased load.
power
With LogicMonitor tracking the servers and applications, as well as power, you’ll be able to see how much more application load your current power infrastructure can supply, so you can convert from requests per second, to Amps, and ultimately dollars of revenue.  That is the power to light up any Datacenter Manager.
Testimonials
If you want an easy to use monitoring solution that is much simpler to set up and maintain compared to things like Nagios and cacti, look at LogicMonitor.
Sam Gendler, VP of Network Operations, VidMe, Inc.
