BGP quietly routes the entire Internet, and when it fails, your users feel it before your internal dashboards ever do.
BGP decides how thousands of independent networks reach each other, but it runs on trust and has no built-in origin authentication
Route leaks and hijacks can redirect, intercept, or black-hole your traffic, causing outages, lost revenue, and breached SLAs
Internal monitoring can show a perfectly healthy application while an external routing problem quietly blocks your users
Add external route visibility alongside your internal telemetry so you can detect leaks and hijacks early, often before customers report them
The Border Gateway Protocol (BGP) quietly runs the Internet. Most people who depend on it rarely have to think about how it works.
This is a beginner-friendly primer for people without a networking background: application owners, CIOs, SREs, and service desk managers.
If you want the deeper technical version, LogicMonitor publishes a complete guide to BGP monitoring. This guide explains what BGP does, how it routes traffic, where it’s weak, and why teams watch their routes.
A working understanding of BGP helps you diagnose outages faster. It also shows why BGP monitoring gives you visibility and early detection, though it doesn’t prevent upstream errors or hijacks.
What BGP is and why it runs the Internet
BGP is the Internet’s primary routing protocol. It directs traffic across the thousands of independent networks that connect to form the Internet.
BGP determines reachability of IP prefixes, blocks of addresses, between autonomous systems. It doesn’t dictate the path of each individual application request. Multiple routing and application-layer decisions affect where a given request ends up.
The original function of BGP was to carry reachability information between edge routers, so networks knew how to find each other. Today it does more, including support for VPNs, IPv6, and Multicast. Its job is to keep the Internet stable while networks constantly change.
The two types of Internet routing
There are two different types of Internet routing, and the distinction explains where BGP fits:
- Interior Gateway Protocols (IGP), such as EIGRP, OSPF, and RIP, route traffic within a single network.
- Exterior Gateway Protocols (EGP), where BGP is the de-facto standard, route traffic between separate networks.
BGP was originally proposed as a stopgap, a temporary fix. It has since become a core protocol for Internet routing. The version in use today is BGP-4.
How BGP works
BGP runs over TCP, which gives it a reliable connection between the routers that speak it. The building block is the autonomous system (AS): a collection of routers under common administration that controls a defined range of IP addresses. Each AS receives a unique Autonomous System Number (ASN).
The protocol makes routing decisions based on paths, rules, and policies rather than simple distance. Each AS keeps a routing table that it shares with its peers. The decision process selects the best available route according to routing policies and path attributes, such as weight, local preference, and AS path length.
That best route isn’t necessarily the fastest or the geographically shortest one. It’s the route that a network’s policies prefer.
BGP was designed to scale across independently operated networks and to apply routing policy. That flexibility comes with a cost: it can be more complex to configure than many routing protocols, and it is comparatively slow to converge when the network changes.
The vulnerabilities built into BGP
BGP runs on trust. There’s little oversight of how each AS configures its peering filters, and the protocol has no built-in origin authentication. That’s why a network can announce an address space that isn’t its own, and why a bad route advertisement can propagate across the Internet before anyone catches it.
That trust model leaves the protocol open to both honest mistakes and deliberate abuse. These show up as two distinct problems:
- Route leaks propagate routing information beyond its intended scope. They most often result from configuration or policy errors, although they can also be malicious.
- BGP hijacks originate or propagate unauthorized routes for another network’s address space. Hijacks can result from mistakes or deliberate attacks; malicious hijacks may redirect, intercept, or black-hole traffic.
Hijacks are hard to detect, so traffic can be redirected or intercepted before the real owner notices. Whether an attacker can actually read or alter the content depends on encryption, such as TLS, and the traffic path. Redirection alone doesn’t guarantee readable data.
How modern teams defend BGP routing
You can’t remove every routing risk, but several practical defenses reduce your exposure. They matter, though they aren’t yet deployed everywhere:
- RPKI and Route Origin Authorizations (ROAs) confirm which AS is authorized to announce a prefix.
- Prefix filtering rejects route announcements that don’t match expected policy.
- External vantage points reveal unexpected announcements for the prefixes you own.
- Route-change alerts and escalation procedures shorten the time to respond.
RPKI is an important origin-validation mechanism, though adoption isn’t yet universal across the Internet.
The impact on users and businesses
When routing goes wrong, the effects reach far past the network team. A leak or hijack can degrade performance for real customers and increase the likelihood of security incidents.
Common consequences include:
- Slow or failed page loads for customers.
- Traffic interception or alteration through man-in-the-middle attacks.
- An entire network black-holed, similar to the outages seen during DDoS attacks.
- Users redirected to malicious or spoofed sites.
- Stolen credentials and data, or delivered malware.
- Censored or blocked destinations.
A malicious hijack can also damage the reputation of the affected IP address space. If an attacker successfully routes traffic for hijacked prefixes and uses those addresses for spam or other abuse, the legitimate prefix owner may later have to deal with blocklists and reputation damage.
For IT leaders and application owners who rarely touch a router, the stakes are concrete. A routing event can mean lost revenue, breached SLAs, and longer incident duration. It can also erode customer trust and widen your security exposure.
How BGP monitoring works in practice
BGP monitoring gives you visibility from outside your network, so you can catch bad advertisements early. Here’s how a diagnosis often unfolds:
- Users report that an application is unreachable.
- Your internal infrastructure looks healthy.
- External route monitoring shows a new announcement or an unexpected origin for your prefix.
- The network team validates the event, checks DNS and traceroute, and contacts the upstream provider.
- The team follows its documented incident-response plan.
When you suspect BGP is involved, a short checklist keeps the investigation focused:
- Confirm that your internal systems and services are healthy.
- Check external reachability to the prefixes you own.
- Look for unexpected origin ASNs or new route announcements.
- Verify DNS resolution and traceroute paths.
Why asymmetric routing complicates troubleshooting
Because networks apply their own policies, traffic can take one path outbound and a different path back. This behavior is called asymmetric routing, and it makes troubleshooting harder. A problem on the return path won’t show up in your outbound view, so you may need visibility from several external vantage points, not just your own egress.
How BGP monitoring connects internal and external visibility
Most teams watch what happens inside their own environment. Internal monitoring can show an application is perfectly healthy while an external routing problem stops users from reaching it. That’s the difference between outside-in and inside-out visibility.
Hybrid, full-stack observability covers that internal view. LM Envision brings together data from infrastructure, cloud, applications, and logs.
BGP lives out on the Internet path, beyond the firewall, where internal tools can’t reach.LogicMonitor Digital Experience shows that layer by monitoring BGP, DNS, and CDN from vantage points around the world. You see route data closer to how users on the Internet experience your traffic.
During diagnosis, external signals and internal telemetry work together. Route monitoring, DNS checks, traceroute, and synthetics show the outside view, while internal telemetry confirms whether your own systems are healthy.
This is how a team separates an internal problem from a routing event upstream, and how it can detect leaks and hijacks earlier, sometimes before customers report them.
See the routing layer your internal tools can’t reach
LogicMonitor pairs full-stack internal observability with global BGP, DNS, and CDN visibility, so you can spot leaks and hijacks and protect users before an outage hits your revenue.
What is BGP in simple terms?
BGP, the Border Gateway Protocol, is the Internet’s primary routing protocol. It tells the thousands of independent networks that make up the Internet how to reach each other by exchanging reachability information for blocks of IP addresses. It decides which network path traffic takes based on policies and path attributes rather than pure distance or speed.
Why is BGP considered vulnerable?
BGP runs on trust and has no built-in origin authentication, so a network can announce address space that isn’t its own. This opens the door to route leaks, which spread routing information beyond its intended scope, and hijacks, which advertise unauthorized routes for another network’s addresses. Both can be honest mistakes or deliberate attacks, and they can redirect, intercept, or black-hole traffic before the real owner notices.
How does BGP monitoring help if I’m not a network engineer?
Internal monitoring can show your application is perfectly healthy while an external routing problem quietly blocks users from reaching it. BGP monitoring adds an outside-in view from vantage points around the world, so you can catch bad route announcements early. For IT leaders and application owners, that means faster diagnosis, shorter incidents, and fewer surprises for customers.
