AIOps & Automation
Unlock AIOps with Red Hat Ansible Automation Platform and LogicMonitor Edwin AI
Learn how LogicMonitor Edwin AI and Red Hat Ansible Automation Platform help ITOps teams move from AIOps insight to governed action.
6 min read
July 14, 2026
Margo Poda
Edwin AI and Red Hat Ansible Automation Platform help ITOps teams move from correlated alerts and root cause analysis to governed, auditable remediation.
  • Edwin AI acts as the intelligence layer, correlating related alerts, adding topology and service context, identifying likely root causes, and recommending response paths.
  • Ansible Automation Platform acts as the execution layer, running approved automation through enterprise controls such as RBAC, policy enforcement, credentials management, audit trails, and human approval.
  • Together, the workflow supports closed-loop AIOps where teams can diagnose incidents faster, automate known responses safely, and expand remediation coverage without removing production safeguards.
When an outage starts, the first alert is only the first artifact. The harder work follows: grouping related signals, separating symptoms from cause, identifying the affected service, and deciding whether the next action is safe to run.
That operating problem shaped the recent webinar with Steve Fulmer, Principal Product Manager for Ansible at Red Hat; Bharat Singh, Head of Product, AI at LogicMonitor; and Callum Brown, Senior Sales Engineer, AI at LogicMonitor. The session focused on a joint model for AIOps automation, with LogicMonitor as the system of intelligence and Red Hat Ansible Automation Platform as the system of action.
IBM watsonx.ai also plays a role in the collaboration, supporting the automation-generation path when a relevant playbook does not exist. Edwin AI helps determine what is happening and what action fits the incident. Ansible Automation Platform governs how that action is executed.
The premise is simple enough to be useful. AIOps has limited value when it stops at alert correlation or a suggested root cause. ITOps teams need a path from signal to action that preserves review, security, auditability, and control.
Why Incident Response Still Takes Too Long
IT teams rarely suffer from a lack of signals. Metrics, logs, alerts, topology, tickets, and automation histories all capture parts of the story. During an incident, those parts often sit across different tools, and responders spend critical time reconstructing context before remediation can begin.
That translation work adds drag. Teams have to determine which alerts belong together, which dependency changed state, which service is affected, which team owns it, and whether a known response already exists. The longer that investigation takes, the more room there is for unnecessary escalation, duplicated work, and avoidable downtime.
AIOps is most useful when it shortens that path from signal to decision. Edwin AI supports that work through event deduplication, enrichment, correlation, incident triage, root cause analysis, similar incident detection, impact analysis, and runbook recommendations. Those capabilities matter because incident response slows across handoffs, rather than at a single point.
Intelligence Needs an Execution Path
Edwin AI fits into this model as the intelligence layer. Edwin AI is built to correlate alerts, identify root causes, group related issues across domains, attach topology and CMDB context, and recommend or initiate remediation workflows.
Incident response depends on sequence. Before a team acts, it needs to know what broke, what is affected, what changed, which service owns the issue, and which response path is appropriate. Edwin AI is positioned to shorten that investigation by bringing incident context into one workflow and using AI agents to assist with triage, diagnosis, and remediation planning.
Red Hat Ansible Automation Platform plays a different role. It is the execution layer, designed to run automation consistently across enterprise environments. Red Hat describes Ansible Automation Platform as a way to turn AI-driven intelligence into governed, auditable, deterministic action. That framing is important because remediation creates risk when it bypasses the controls teams use to protect production systems.
In the joint pattern discussed in the webinar, Edwin AI identifies and reasons over the incident, then Ansible Automation Platform executes approved automation through policy, credentials, role-based access, and audit trails. The value comes from connecting the two systems without removing governance from the process.
How the Joint Edwin AI-Ansible Automation Platform Workflow Runs
The workflow begins with LogicMonitor alerts that are prioritized and correlated, reducing the number of separate symptoms responders have to interpret. Edwin AI then analyzes the incident context, including what is happening, what appears to matter, and which response path may fit.
From there, the workflow connects to Ansible Automation Platform through the Ansible API to discover and use existing playbooks. If an approved playbook exists, Ansible Automation Platform can execute it with enterprise controls such as RBAC, audit trails, Ansible Vault, policy enforcement, and human approval.
When no relevant playbook exists, Ansible automation coding assistant and IBM watsonx.ai can help generate proposed Ansible automation. That generated content should move through review, testing, and approval before production use, because generated automation still carries operational risk.
The workflow can also synchronize with ITSM systems, remediate the issue, and feed closed-loop learning. Over time, resolved incidents can improve future diagnosis, routing, and automation coverage.
Embed code:
Edwin AI identifies incident context, recommends the next action, and connects to Red Hat Ansible Automation Platform for governed remediation.
Governance Makes AI-Assisted Action Usable
AI-assisted remediation depends on more than a plausible recommendation. Production environments need credential boundaries, approval paths, policy enforcement, and audit history that match the risk of the action being taken.
Ansible Automation Platform provides the governed execution layer for that work. Operators can use the Web UI to configure, launch, and monitor automation through a role-based interface. Third-party systems can integrate through the API using token-based authentication. Event-Driven Ansible can trigger automation from external event sources. MCP can allow AI models to query Ansible Automation Platform and launch automation within defined boundaries.
That last boundary is important. AI can help identify a likely fix, but execution still needs to respect the organization’s control model. The safer pattern is proposed action flowing into governed automation, with approval and auditability preserved where the risk requires it.
Event-Driven Automation With LogicMonitor Envision
The webinar also covered an event-driven pattern using LogicMonitor Envision and Red Hat Ansible Automation Platform. LogicMonitor Envision captures alerts, and the LogicMonitor.integration Content Collection sends events through a webhook.
Event-Driven Ansible picks up the event, evaluates it against an Ansible Rulebook, and calls a playbook or job template when the defined conditions are met. That workflow can then remediate an issue across hybrid cloud infrastructure or trigger a lower-risk action such as ticket enrichment or automated fact gathering.
This gives teams a practical starting point. Early workflows can improve incident context, notify the right team, or collect diagnostics before a responder joins the incident. More mature workflows can handle service restarts, backups, rollbacks, drift response, compliance response, and certificate management.
Where Teams Can Start
The safest starting point is often a workflow that improves incident context before touching production systems. Teams can automate ticket creation, enrich alerts with topology and ownership data, attach incident summaries, notify the right responders, or gather diagnostic information before escalation.
From there, teams can add response workflows where the action is well understood and the rollback path is clear. Common candidates include certificate management, service restarts, threshold-based actions, backup triggers, configuration checks, and known remediation steps for recurring incidents.
The business case should stay grounded. The measurable outcomes are faster incident resolution, fewer escalations, reduced after-hours toil, stronger SLA performance, and more consistent execution across teams.
Closing the Loop
The webinar’s strongest takeaway is that AIOps needs a path into controlled action. Edwin AI helps teams understand what is happening across complex environments. Ansible Automation Platform gives teams a governed way to act on that understanding. AI-assisted automation can help expand coverage, provided proposed workflows are reviewed and approved before use.
That combination moves ITOps closer to self-healing operations without asking teams to abandon the controls that make automation safe enough for production.
Watch the webinar on demand
Margo Poda
By Margo Poda
