3000+ Integrations
3000+ Integrations
Digital X Cologne
Cologne
3000+ Integrations
Digital X Cologne
Why ITOps Automation Is Hard, Until You Change Your Approach
AI-driven automation promises speed and scale, but most ITOps teams hit the same structural limits as automation expands. This article explains why and what changes in 2026.
10–15 minutes
January 27, 2026
Margo Poda
The quick download
Automation fails in ITOps because it’s treated as a local efficiency gain rather than a system-level change—an approach that breaks down at scale as AI raises the bar for context, ownership, and control.
  • Automation fails in ITOps because it is introduced as a local efficiency fix into a tightly coupled system.
  • Early wins conceal structural problems that surface as automation scales.
  • In 2026, AI-driven automation raises the cost of those problems by increasing expectations for traceability and control.
  • This article sets up five structural barriers that explain why “just automate it” keeps breaking down.
Modern ITOps environments are hybrid, distributed, and assembled from overlapping vendors and platforms. Services run across clouds and teams. Signals arrive continuously. Dependencies change faster than they can be documented. Human operators struggle to maintain consistent awareness, let alone respond with precision.
Automation enters as a rational response to that pressure. It absorbs volume, reduces manual effort, and promises faster response. At first, it delivers. Scripts remove repetitive tasks. Workflows resolve common incidents. Playbooks shorten recovery for familiar failure modes.
The problems begin when automation moves beyond isolated fixes. As it spreads, assumptions harden into logic, logic hardens into workflows, and workflows accumulate without shared ownership. Decision-making fragments. Change control weakens. What helped at small scale starts to introduce risk at system scale.
This failure is often blamed on tooling. That diagnosis misses the point. Scripts execute correctly, and platforms behave predictably. The mistake, instead, is structural. Automation is treated as an additive layer rather than a change to how decisions are made, who holds authority, and how actions are reviewed.
That mistake is harder to defend in 2026. AI-driven automation increases autonomy while tightening scrutiny. Automated actions now require justification, auditability, and clear lines of responsibility. Systems must show why they acted and under what constraints.
In ITOps, automation touches incident response, remediation, and change execution. Its value only appears when it reduces operational load and failure frequency without introducing new modes of failure.
The five barriers that follow explain why this is difficult to achieve in practice. They are longstanding. What has changed is the requirement to scale automation while increasing accountability at the same time.
Barrier 1: Automation can act, but it doesn’t always know when or why
Automation can execute actions. It cannot decide which action is appropriate without context.
Observability systems surface symptoms like alerts, anomalies, threshold breaches. Automation systems execute responses: restarts, failovers, configuration changes. What sits between them is decision-grade context—service impact, dependency relationships, recent changes, historical outcomes, and operational constraints. That layer is often missing.
When context is absent, automation degrades in predictable ways. Teams either restrict execution so heavily that automation rarely runs, or they allow execution based on incomplete signals and accept the risk. Both outcomes limit value.
This gap shows up daily. Alert streams grow noisy, so teams suppress signals rather than resolve underlying causes. Engineers fall back on memory and habit when incidents occur, choosing runbooks based on familiarity instead of evidence. The result is inconsistency, slower recovery, and repeated failure patterns.
Closing the gap requires treating context as a first-class system, not an afterthought. Signals need to be mapped to services, services to dependencies, dependencies to recent changes, and changes to known remediation outcomes. Event intelligence—correlation, deduplication, and enrichment—must come before automated remediation. Acting on raw alerts scales noise, not resolution.
In 2026 and beyond, agentic systems will act with greater and greater autonomy, but autonomy without context produces confident errors at higher speed.
How context graphs scale autonomous IT beyond ITOps
Barrier 2: Automation is cross-functional, but ownership isn’t
Automation rarely belongs to a single team. Execution touches monitoring, application ownership, security controls, change management, ITSM, and platform engineering. Each brings different priorities, risk tolerances, and success metrics.
When alignment is weak, automation can quickly turn into a source of organizational friction. One team measures success by ticket closure speed. Another measures the change failure rate. A third cares about audit findings. Automation that satisfies one group can create work or risk for another. Disputes emerge after deployment, when reversing course is costly.
The symptoms are familiar. Teams optimize local KPIs while global outcomes degrade. Incidents close faster, but recur more often. Automation work stalls in approval queues or is quietly blocked after a single visible failure. Over time, teams stop investing because the path forward feels unpredictable.
The fix is explicit ownership. Effective programs establish a sponsor agreement before execution begins. That agreement defines the outcome being optimized, acceptable blast radius, rollback expectations, and error budgets. It also clarifies which actions are allowed under which conditions.
Automation must sit under the same governance as production changes. Versioning, approvals, and auditability are not overhead. They are the mechanism that allows multiple teams to trust shared execution.
Analyst warnings about agentic initiatives failing due to cost, complexity, and unclear value describe this exact dynamic at larger scale. Autonomy amplifies misalignment. Without shared incentives, automation does not fail quietly.
Barrier 3: Automation changes the work, not the workload
Automation shifts responsibility within ITOps rather than reducing it.
Hands-on execution is replaced by decision design, validation, exception handling, and ongoing maintenance of system behavior. Work moves earlier in the lifecycle, where conditions are defined and constraints are set, and later, where outcomes are reviewed and corrected. This form of work requires skills in data interpretation, workflow logic, policy definition, and diagnosing behavior across distributed systems.
Most organizations introduce automation without adjusting how work is owned, staffed, or sustained. Existing roles are expected to take on design and oversight responsibilities alongside operational duties. Time is not allocated for maintaining decision logic once it is deployed. Ownership of automated behavior remains unclear.
The resulting symptoms are consistent:
  • Automation platforms are licensed and integrated but limited to narrow, low-risk workflows
  • Outputs are bypassed because decision logic cannot be inspected or explained
  • Skill constraints concentrate responsibility in a small group, creating bottlenecks
  • Automation artifacts persist without active stewardship and degrade over time
These outcomes reflect operating models that are not structured to support decision-making systems. These same constraints have been identified across AI and automation programs: skill shortages, weak governance, and data platforms that cannot sustain higher-order decision logic in production. When these constraints remain unresolved, automation usage declines regardless of tooling.
Progress requires treating enablement as an operating capability. Decision logic must have clear ownership. Execution patterns must be standardized. Contribution paths must be explicit. Automation that depends on informal expertise or individual initiative does not sustain trust.
Human oversight must be deliberately defined. Review points, approval thresholds, and escalation conditions need to exist before execution authority expands. Autonomy increases only when systems continue to behave predictably as conditions change.
Barrier 4: Technical debt and last-mile fragility
Early automation efforts usually focus on predictable work. Tasks with clear triggers and repeatable outcomes are easy to encode, and early success reinforces further investment.
Progress slows when automation moves beyond repetition and into work shaped by conditions. Behavior begins to depend on upstream dependencies, partial failures, platform changes, and incomplete data. These cases resist generalization. They require ongoing adjustment rather than one-time logic, and effort concentrates here as systems grow more complex.
A common example is alert-driven remediation. A workflow is introduced to restart a service when a specific alert fires. At first, it works reliably. Over time, the same alert begins triggering in new situations—dependency failures, degraded network paths, platform upgrades, or changes in alert thresholds. The automation still executes, but the context has shifted.
The service restarts when it shouldn’t. Downstream systems experience brief outages or instability. Engineers begin disabling the automation during incidents because its behavior is no longer predictable under degraded conditions. Recovery slows, not because the task itself is difficult, but because the automated path is no longer trusted.
At this stage, execution quality erodes. Logic accumulates faster than it can be reviewed or maintained. Ownership becomes unclear. When automation fails, recovery falls back to manual intervention because rollback and recovery paths were never defined. Platform changes introduce new failure modes, and restoring service takes longer than performing the task manually.
This breakdown is not caused by automation itself. It’s caused by unconstrained execution. Each workflow carries its own assumptions about state, failure, and recovery. Those assumptions are rarely documented, rarely tested, and rarely revisited as the environment changes. Over time, the system becomes difficult to inspect and expensive to repair.
Programs that hold up over time limit how automation is allowed to run. Execution is shaped around a small set of standardized workflows with defined inputs, outputs, and failure handling. Behavior is versioned, reviewed, and observable. Automation is designed to tolerate retries, limit side effects, and surface measurable outcomes rather than silently acting in the background.
Automation-related debt becomes visible in these systems. Abandoned workflows, change-induced failures, and increasing recovery time all indicate whether execution is becoming harder to operate. When these signals are ignored, progress flattens and trust in automation declines.
This pressure increases as agent-driven execution is introduced into existing environments. Agents don’t just execute tasks—they chain decisions across systems. Integration paths multiply. Permission boundaries tighten. Data quality limits action. Model capability improves, but execution fails when the underlying systems cannot absorb additional complexity. Agents don’t fix fragile automation. They expose it faster.
Barrier 5: Automation needs controls
As automation gains the ability to act directly on production systems, errors move faster and spread wider. Decisions that once passed through human review now execute immediately. When those actions are not bounded, the system absorbs risk without a clear way to explain or contain it.
Teams adapt in predictable ways. Security restricts execution paths to limit exposure. Operations bypass those restrictions to maintain availability. When failures occur, review stalls because the system acted without a visible decision trail or clearly defined limits.
Automation that survives in production treats authority as something to be earned and constrained. Some outputs remain advisory. Some actions require approval. Fully automated execution is limited to situations with known impact and defined recovery. Expansion follows demonstrated behavior under change.
Controls have to shape execution from the start. Authorization defines who can permit action. Logging preserves the conditions and inputs that led to execution. Policy boundaries limit scope. Automation includes mechanisms to stop or reverse behavior when outcomes diverge from expectation.
External pressure now reinforces these requirements. The EU AI Act formalizes expectations around traceability, transparency, and human oversight beginning in August 2026. Similar criteria appear in enterprise procurement and risk reviews, regardless of geography.
At this stage, governance determines whether automation can operate continuously or remain confined to supervised use.
How to sequence AI automation without blowing up trust
Expanding execution before uncertainty is addressed increases exposure. When control, evidence, and accountability aren’t established first, unresolved assumptions compound as automation scales.
The sequence below reflects how these elements are put in place before execution widens, so progress can continue without introducing instability.
  • Stabilize signals: correlate events, remove duplicates, and enrich alerts with basic operational context.
  • Recommend actions: surface the most relevant runbook or playbook without executing it.
  • Enable guardrailed execution: allow automation to act within defined limits using approvals, role-based access, and audit logs.
  • Introduce event-driven remediation: execute scoped self-healing for well-understood scenarios with predictable impact and rollback.
  • Expand autonomy: increase automated execution only after sustained evidence of safety and improved outcomes.
Each step closes failure modes that become harder to manage once execution is delegated.
Agentic automation raises capability and responsibility together
Agentic automation refers to systems that interpret operational signals, select actions, and coordinate execution with reduced human intervention.
In practice, this compresses decision cycles and shifts responsibility deeper into the system. The barriers outlined in this article—context gaps, unclear ownership, fragile execution, and missing controls—become limiting factors sooner and with greater impact.
These requirements already exist in ITOps environments. Agentic systems surface them earlier because execution occurs with less mediation and tighter coupling to production systems.
This dynamic explains why many agentic initiatives remain constrained. Analyst research consistently shows programs stall when integration introduces operational risk or when outcomes cannot be defended after the fact. The constraint is not model capability. It is whether the surrounding system can support autonomous execution without loss of control.
Teams that progress treat agentic automation as a continuation of automation practice. Context precedes autonomy. Ownership precedes execution. Controls are designed into behavior rather than added after incidents.
This sets the conditions under which agentic automation can operate in production without eroding trust.
Edwin AI: How LogicMonitor approaches these barriers
The barriers outlined above define the conditions under which agentic automation can operate in production without introducing unmanaged risk. They describe a system requirement, not a tooling preference.
Edwin AI is LogicMonitor’s approach to agentic automation for ITOps environments that operate under those constraints. It connects observability insights to operational decisions and then to controlled execution, using the platforms teams already depend on.
At its core, Edwin AI functions as an ITOps agent that interprets signals, recommends actions, and executes remediation within defined boundaries. It operates across existing tools and workflows rather than replacing them.
How Edwin AI addresses the core barriers to AI automation
  • Closing the context gap: Edwin AI connects metrics, logs, traces, and events to services, dependencies, incidents, and remediation options. Decisions are based on operational context rather than isolated alerts, reducing inappropriate or mistimed actions.
  • Working across silos: Edwin AI correlates infrastructure, application, and Internet performance signals—including Catchpoint’s Internet and digital experience telemetry—so automation decisions reflect shared service reality across ITOps, NetOps, SRE, and app teams, without forcing tool consolidation or ownership changes.
  • Reducing skill bottlenecks: Edwin AI recommends relevant remediation playbooks and assists with playbook creation. This lowers reliance on tribal knowledge and reduces the effort required to participate in automation, while keeping humans accountable for execution.
  • Containing last-mile fragility: Remediation is handled through standardized playbooks with repeatable execution paths. This replaces ad hoc scripts with artifacts that can be reviewed, versioned, and reused.
  • Preserving control: Execution is governed through role-based access, approvals, and auditability. Automated actions remain attributable and explainable, even as execution authority expands.
What Edwin AI’s AI automation enables in practice
Edwin AI supports two practical AI automation motions:
  • Identifying the most appropriate playbook for a given incident and executing it when permitted.
  • Generating new playbooks from observed patterns and incident analysis to expand coverage without increasing fragility.
Together, these capabilities reduce response time, limit manual decision load, and improve consistency without bypassing operational controls.
Edwin AI does not position agentic automation as an abrupt shift to full autonomy. It provides a controlled way to move from insight to action, with context and governance built in. For ITOps teams under pressure to automate without increasing risk, Edwin AI offers a path to higher autonomy that remains operationally defensible.
See how AI automation will shift your team from reactive to proactive with Edwin AI.
Get a demo
By Margo Poda
Blog AIOps & Automation
September 4, 2026
September 2, 2026
September 1, 2026
