    Combine synthetic and real user monitoring in one platform.
    LogicMonitor unifies synthetic checks and RUM data so you can correlate scripted baselines with live user experience, all from a single telemetry pipeline.
    What is the main difference between RUM and synthetic monitoring?
    RUM passively collects performance data from actual user sessions in production, while synthetic monitoring proactively simulates user transactions using scripted agents. RUM shows you what real users experience; synthetic testing shows you what users would experience under controlled conditions.
    Can I use synthetic monitoring to test pre-production environments?
    Yes. Because synthetic monitoring uses scripted agents rather than real user traffic, it’s well suited for testing applications in staging and QA environments. You can establish performance baselines before going live and set appropriate alert thresholds.
    Do I need both RUM and synthetic monitoring?
    A comprehensive monitoring strategy includes both. Synthetic monitoring provides 24/7 proactive detection and SLA tracking, while RUM correlates real user behavior with business metrics like conversion rates. Together, they give you a 360-degree view of application performance.
    How do RUM and synthetic monitoring help with troubleshooting?
    When synthetic tests fail, RUM data shows the real-time impact on actual users. When RUM reveals an anomaly, synthetic monitoring can replicate the issue across multiple ISPs and locations to triangulate the root cause in the data path.
    By Denton Chikura
    Technical Writer
