OBSERVABILITY VS MONITORING
Cloud Performance
Cloud performance depends on more than your infrastructure. Learn how DNS, CDNs, network routing, and external monitoring shape the experience your users actually get.
12–18 minutes
June 24, 2026
Denton Chikura
IN THIS DEEP DIVE
CHAPTERS
    Cloud performance lives and dies on the Internet stack, not on your servers.
    • Your application can respond in 200 milliseconds and still deliver a terrible user experience when DNS, CDN, or ISP routing breaks down along the way.
    • Synthetic monitoring from external vantage points catches regional outages, ISP-specific problems, and network path issues that internal dashboards can’t see.
    • Coordinating DNS and CDN decisions, building multi-provider resilience, and monitoring external dependencies are the highest-leverage moves for consistent global performance.
    • Start with one critical user journey, monitor it from multiple external points, and measure the business impact before expanding.
    Cloud Performance
    Most cloud performance problems don’t originate in the cloud.
    Your application can respond in 200 milliseconds and still feel slow to users. DNS resolution, CDN coverage, ISP routing, and third-party services often contribute more latency than the application itself. Yet many teams monitor only the infrastructure they control and miss the systems users actually depend on.
    The result is a familiar disconnect: internal dashboards stay green while users experience slow page loads, failed transactions, and intermittent outages that never appear in application metrics.
    Cloud performance is ultimately an end-to-end problem. To understand it, you need visibility into the entire Internet path between users and your application. The following sections cover how modern Internet performance monitoring provides that visibility, working through DNS, CDN, network routing, synthetic monitoring, and real user data.
    Summary of key cloud performance best practices
    Best practiceDescription
    Build DNS resilienceSet up multiple DNS providers with performance-based routing and smart caching. Don’t rely on just one provider, either. Use geographic distribution and monitor performance across providers to keep domain resolution fast and reliable.
    Build robust CDN systemsUse multiple CDNs with edge computing and smart content placement. Warm your caches in advance and ensure your CDN choices align with your DNS routing for consistent global performance.
    Design synthetic monitoringMonitor from outside your infrastructure using points that match real user experiences across different locations and network types. Watch complete user journeys, not individual steps, and focus on the actual paths users take.
    Optimize for user experienceConnect technical metrics to user satisfaction using Core Web Vitals and real user monitoring. Track loading speed, interactivity, and visual stability, plus frustration signals that show problems your regular metrics miss.
    The foundations of Internet Stack performance
    The Internet stack includes all the layers between users and applications. Real-world networks don’t match the clean diagrams in textbooks. Performance depends on messy, unpredictable, real-world paths.
    If you have applications deployed in the cloud, your user requests travel across infrastructure outside your control. The request leaves the user’s device and traverses local networks, Internet service providers, content delivery networks, and load balancers before reaching your servers, as shown in the diagram below.
    Each hop adds latency, and each system can fail. Application-centric monitoring alone misses these external factors. An application responding in 200 milliseconds can still deliver a poor user experience when other stack components fail.
    Path variation also significantly affects performance. A user in Tokyo accessing your New York-based application follows a completely different route than someone in London. Network conditions change hourly, and infrastructure configurations vary by provider. The same application can perform differently even for users just a few miles apart.
    Infrastructure monitoring tools measure your environment well, but they don’t extend to the Internet infrastructure that your users’ requests and responses actually traverse.
    Critical cloud infrastructure components
    Three Internet stack components have an outsized impact on user experience: DNS, content delivery networks (CDNs), and network routing. Together, they determine whether users can reach your application, how far requests must travel, and how quickly content is delivered.
    Many organizations spend months optimizing application code while overlooking these layers. Yet a DNS outage can make a healthy application completely unreachable. A poorly positioned CDN can add hundreds of milliseconds of latency. Inefficient network routing can degrade performance even when every internal service is functioning normally.
    DNS resolution initiates every user interaction. Recursive servers (operated by ISPs and providers like Google) cache responses, while authoritative servers store official domain records. The speed and reliability of that resolution affects every page load before a single byte of application content is served.
    CDNs do more than cache static files. Modern CDNs perform edge computing, run API gateways, and optimize dynamic content. The decision to serve from the edge or fetch from the origin happens in milliseconds, but the impact accumulates across every request. The fastest route serves cached content directly from the CDN edge; cache misses trigger the longer path through origin servers, adding hundreds of milliseconds.
    Network routing through BGP determines the path requests take across the Internet. Because those paths vary by region, provider, and time of day, two users accessing the same application can experience dramatically different performance — and neither will appear in your infrastructure metrics.
    Simple Internet stack showing request flow and failure points
    The request path above reveals why external infrastructure matters more than application code. The fastest route serves cached content directly from the CDN edge. Cache misses trigger the longer path through origin servers, adding hundreds of milliseconds. When either the CDN or the origin fails, users experience service degradation regardless of how well-architected the underlying application is.
    Make your network and content delivery resilient
    The fastest path between users and your application depends on DNS, CDN coverage, and the network routes in between. To keep experiences consistent, you need domain resolution that survives provider outages and content delivery architectures that stay close to users even as traffic patterns shift. The following sections cover how to build DNS resilience and design robust content delivery systems that work together instead of in isolation.
    Building DNS resilience means making interconnected decisions that affect millions of queries daily. Because DNS providers have a track record of regional outages, relying on a single provider creates a failure mode that only becomes visible when something breaks. The practical questions, such as when secondary providers kick in and how to split traffic without disrupting users, depend entirely on where your users are and how they connect.
    Performance-based routing addresses part of this by automatically directing each query to the fastest available provider. It requires monitoring that detects problems quickly and validates that failover behaves as expected under real conditions, not just in testing.
    Cache configuration involves real tradeoffs. Longer TTLs reduce query load and improve speed, but slow recovery when a provider begins failing. Shorter TTLs enable faster failover but increase DNS load during peak traffic. Neither is universally correct. The right setting depends on your provider’s reliability and traffic patterns.
    Negative caching adds further complexity. When DNS lookups fail, recursive servers cache those failures to avoid repeated attempts. Misconfigured negative caching means one provider failure propagates broadly. Users can’t reach the application because their DNS is caching the failure itself rather than a valid resolution. This is one of the less obvious ways a single DNS provider dependency creates outsized risk.
    Build robust content delivery systems
    DNS and CDN performance are linked, and the failure to treat them together is a common source of inconsistent results. Fast DNS resolution followed by slow content delivery is a worse user experience than mediocre performance at both layers, because the user waits through both delays sequentially.
    A pattern that emerges frequently during geographic expansion illustrates this: DNS resolves correctly to regional servers, but limited CDN presence in that region means requests route back to distant origin servers for content. The DNS optimization was real. The performance benefit didn’t materialize because the bottleneck simply moved downstream.
    Content placement strategy affects everything that follows. Static content can be served reliably from edge locations closest to users. Dynamic content is more complex. Some requests require communication with the origin server, which eliminates the edge-delivery advantage. Other dynamic content can benefit from edge processing, but only if the application is architected to support it.
    Data replication strategy needs to match DNS routing decisions. Full replication delivers the fastest access but increases cost and synchronization complexity. Selective replication based on content popularity controls costs but requires accurate prediction of what users in each region will request. Cache warming, or pushing content to edge locations before users ask for it, sidesteps some of that prediction challenge, but only works when DNS routing directs users to the correct edge locations in the first place.
    Multi-CDN architecture introduces the same coordination complexity as multi-provider DNS. Different CDNs perform better in different regions and for different content types. Performance-based load balancing continuously monitors CDN health and routes traffic to the fastest available provider for each user, enabling automatic failover when a provider degrades.
    Implement effective cloud performance monitoring
    To understand cloud performance, you need visibility into both the paths users take and how those paths feel in use. Synthetic monitoring reveals where requests fail or slow down, and user experience optimization turns that insight into faster, more reliable journeys
    Synthetic monitoring design
    Infrastructure monitoring answers the question: “Are my systems healthy?” Synthetic monitoring answers a different question: “Can users successfully use my service?”
    Both questions matter, and neither can replace the other. An infrastructure monitoring tool watching from inside your network can’t detect a DNS outage that prevents users from resolving your domain. It can’t see an ISP-specific routing problem affecting users in one region. It can’t tell you that your checkout flow fails for mobile users on a specific carrier. Synthetic monitoring from external vantage points catches all of these. Catchpoint, part of the LogicMonitor platform, runs over 3,000 monitoring points inside major ISPs, mobile carriers, and cloud providers. That distribution detects regional issues, ISP-specific problems, and network path degradation that infrastructure monitoring can’t surface.
    Global Catchpoint presence
    Geographic coverage matters, but vantage point selection matters more than the number of vantage points. Rural networks, smaller ISPs, and markets in developing regions behave differently from major metropolitan locations, and averaged metrics obscure those differences. Monitoring from 50 points in the same metropolitan area tells you far less than monitoring from 10 points distributed across different ISPs and network types.
    Synthetic tests should replicate complete user workflows, from landing page load through checkout completion, rather than checking individual endpoints. A component that tests healthy in isolation can contribute to a broken end-to-end experience. Performance thresholds should reflect user expectations, not internal SLA targets. An API response at 500ms may satisfy a technical SLA while contributing to a total load time that causes users to leave.
    User experience optimization
    Real user monitoring captures what’s happening in production across the full range of devices, browsers, and network conditions your users actually encounter. Browser performance data connects infrastructure metrics to user experience, making it possible to see how DNS resolution time, connection establishment, and content loading accumulate to affect perceived page speed.
    Core Web Vitals provide standardized metrics with documented correlations to user satisfaction:
    • Largest Contentful Paint (LCP) measures when the primary content of a page appears. Users form their first impression of speed based on this, not on total load time.
    • Interaction to Next Paint (INP) measures responsiveness across all user interactions on a page. It identifies pages that feel slow to interact with, even when load times appear acceptable. This is a common source of user frustration that earlier metrics missed.
    • Cumulative Layout Shift (CLS) captures visual instability: the experience of content shifting or jumping around while a page loads. High CLS scores correlate with accidental clicks and user abandonment.
    Connecting those metrics to frustration signals, including rage clicks, dead clicks, and error rates, reveals user impact even when technical metrics look acceptable.
    Server response times and user experience don’t always move together. Servers can respond quickly, while third-party scripts loading on the client side add seconds of perceived wait time. That class of problem doesn’t appear in server-side metrics. Real user monitoring surfaces it; infrastructure monitoring typically doesn’t.
    Control your extended infrastructure
    As your applications span multiple clouds and third‑party services, performance depends on infrastructure you don’t own as much as the systems you do. Controlling that extended footprint means monitoring how providers interact, routing traffic based on real‑time behavior, and validating vendor health against what users actually experience.
    Multi-cloud management
    Most applications today span multiple cloud providers. The resilience and cost benefits are real, but multi-cloud environments also introduce performance complexity that infrastructure monitoring alone doesn’t cover.
    Load balancing across clouds requires real-time decisions that go beyond simple round-robin distribution. Geography, current load, historical performance, and pricing differences all affect which routing decisions make sense. Health checks need to distinguish temporary blips from failures that require immediate action. Treating them the same degrades both reliability and user experience.
    Identifying root cause across cloud environments is harder than in single-provider setups, because the failure could sit in your infrastructure, a third-party dependency, or the network path between them. Internet Sonar addresses this by comparing performance across different vantage points and services, making it possible to isolate where degradation is actually originating. During high-traffic periods, this distinction determines whether a team investigates its own systems or escalates to a vendor, and how quickly it makes that call.
    Latency-based geographic routing directs users to the fastest available infrastructure, but network conditions shift continuously, so “fastest” changes over time. Backup routing paths need to be defined in advance, which requires understanding how your providers connect to each other, not just how they connect to users.
    External dependency control
    Vendor health is not the same thing as user experience.
    A payment provider can report 99.99% availability while users in a specific region experience elevated latency, intermittent failures, or degraded transaction performance. A status page labeled “operational” reflects the vendor’s infrastructure metrics, not what users are actually experiencing. Monitoring must validate what users experience, not simply what vendors report.
    This distinction matters most for high-value workflows. Users encountering a slow or failing checkout will abandon the transaction. Revenue disappears while the vendor’s SLA remains technically satisfied.
    Error rate tracking and response time monitoring surface reliability gaps that SLA compliance reports don’t. Percentile analysis gives a more accurate picture than averages — the 95th and 99th percentile response times are where user-impacting problems concentrate. An average that looks acceptable can hide a significant portion of users experiencing serious delays.
    API performance tracking should go beyond connectivity checks to ensure the service is functioning correctly. The impact of rate limits needs to be assessed separately to understand how third-party constraints affect your application during peak usage. Timeout configuration requires calibration: timeouts set too short generate false failures during temporary slowdowns; timeouts set too long create poor user experiences when services genuinely fail. Error handling should degrade functionality gracefully rather than allow third-party failures to cascade.
    Stripe payment processing fails in one region; the payment service can’t process transactions and returns errors. Cart service slows down due to payment timeouts and retries. Users experience checkout failures despite all internal systems showing “healthy.”
    Drive performance through visibility
    Visibility becomes valuable when it connects Internet‑stack performance to user outcomes and future decisions, not just dashboards and alerts. By correlating external monitoring data with business metrics, you can see which issues matter most, justify investments, and design cloud strategies that stay resilient as architectures and markets evolve.
    Measuring cloud performance impact
    Performance data becomes more valuable when it’s connected to business outcomes.
    A two-second reduction in page load time means very little on its own. The same improvement tied to conversion rate, checkout completion, revenue, or customer retention creates a clear business case for further investment. The most effective teams measure both technical performance and user outcomes so they can prioritize work based on business impact rather than intuition.
    Baselines should reflect user experience, not just technical measurements. Seasonal traffic analysis helps separate normal fluctuation from genuine degradation — peak shopping periods look nothing like typical weekday traffic, and thresholds calibrated for one context generate noise in another.
    Infrastructure monitoring provides depth on individual components. LogicMonitor’s Catchpoint extends that visibility across the full Internet stack, from the end user through the Internet path to the underlying infrastructure. Correlating metrics, traces, and logs across those layers accelerates root cause analysis and surfaces optimization opportunities that component-level monitoring misses.
    User experience metrics worth tracking are those that align with business outcomes and remain meaningful to technical teams. Customer satisfaction scores, task completion rates, and engagement data provide the business context that turns a performance improvement into a justifiable investment.
    Future-ready strategies
    Edge computing, 5G, and serverless architectures are changing how applications deliver experiences. As systems become more distributed and more dependent on third-party services, the set of external dependencies that affect user experience grows larger and less predictable.
    Scaling plans should address geographic expansion and service diversification, not just added capacity. Consistent visibility across new markets requires monitoring infrastructure designed with that scope in mind, not retrofitted after the fact.
    The cost of poor performance, in abandoned sessions, lost transactions, and damaged user trust, typically exceeds the cost of the monitoring that would have detected and prevented it. Starting with one critical user journey, monitoring it from multiple external vantage points, and measuring the business impact creates a foundation that’s easier to expand than to build from scratch later.
    The bottom line
    See what your dashboards are missing across the Internet stack.
    Your users’ experience depends on DNS, CDNs, ISPs, and third-party services that infrastructure monitoring alone can’t reach. LogicMonitor’s Catchpoint gives you visibility from over 3,000 external vantage points, so you can find and fix problems before they hit revenue.
    Request a demo
    What’s the difference between cloud performance and application performance?
    Cloud performance covers the entire transaction path from user to application and back, including DNS resolution, CDN delivery, ISP routing, and third-party services. Application performance focuses only on how your code and servers respond. You can have excellent application performance and still deliver a poor user experience if other parts of the Internet stack are slow or failing.
    Why do internal monitoring dashboards miss cloud performance problems?
    Infrastructure monitoring watches your environment from inside your network, and it’s essential for what it covers. It doesn’t extend to the DNS, CDN, ISP, and routing layers that users’ requests actually traverse, though. When a regional ISP has congestion or your CDN cache misses in a specific geography, your internal dashboards stay green while users experience delays or failures. That’s why infrastructure monitoring and Internet performance monitoring work best together.
    How does synthetic monitoring differ from Real User Monitoring (RUM)?
    Synthetic monitoring runs scripted tests from external locations to proactively detect problems before users encounter them. RUM collects performance data from actual user sessions in production. Both are valuable: synthetic monitoring catches issues early and provides consistent baselines, while RUM shows the real distribution of user experience across devices, locations, and network conditions.
    What should I monitor first to improve cloud performance?
    Start with one critical user journey, such as your checkout flow or signup process. Monitor it from multiple external vantage points that match where your users actually connect from. Measure both technical metrics (DNS resolution time, TTFB, LCP) and business metrics (conversion rate, cart abandonment). This gives you a clear baseline and shows the business impact of any improvements you make.
    By Denton Chikura
    Technical Writer
