Playwright synthetic monitoring turns your browser tests into continuous coverage of the customer and employee journeys your business depends on.
Simple uptime checks and URL pings can’t validate multi-step flows like checkout, login, or subscription renewal, so failures quietly cost revenue and conversions
Running Playwright inside LogicMonitor executes your scripts on a schedule from thousands of global agents, revealing exactly where and when a journey breaks
Built-in assertions, wait methods, tracepoints, and secure credential storage confirm each step works and pinpoint the source of any slowdown
Import an existing Playwright test and schedule it from the locations your users connect from to start catching issues before your customers do
Modern web transactions depend on JavaScript, APIs, third-party services, and authentication. Basic uptime checks and simple URL pings can’t verify these multi-step workflows. When a checkout or login breaks, you lose revenue, hurt conversion, and generate support tickets.
Playwright synthetic monitoring closes that gap. Running Playwright scripts inside LogicMonitor Digital Experience platform turns your browser tests into continuous, outside-in monitoring from distributed agents.
This article covers when to use Playwright, what you gain from running it on the platform, how the workflow operates, and how to get started.
What is Playwright?
Playwright is a browser automation framework that simulates real user interactions across multiple browsers. Developers use it to test that a page navigates, clicks, and confirms results the way they expect. Its API is clean, so scripts stay readable.
Synthetic monitoring takes that idea further. Instead of running a test once during development, you run the same script on a schedule from many locations. That turns a one-time check into continuous coverage of the journeys your customers rely on.
Key features of Playwright
- Multi-browser support. Playwright automates tests across different browser agents, including Chrome and Edge.
- Rich API for actions. It handles clicks, text entry, selections, and navigation.
- Robust assertions. It validates elements, text content, URLs, and attributes.
- Asynchronous handling. Methods like waitForSelector, waitForEvent, and waitForResponse keep tests reliable in dynamic environments.
- Execution. You can import Playwright scripts inside the platform for a consistent approach to testing and monitoring.
When to use Playwright synthetic monitoring
Playwright fits synthetic monitoring better than a simple URL or API check when the experience has real interaction behind it. Reach for it in these cases:
- Multi-step transactions. Checkout, onboarding, and subscription renewal span several pages.
- Single-page applications. These apps render content with JavaScript instead of full page loads.
- Authenticated journeys. These flows sit behind a login and need valid credentials.
- Dynamic content. These pages load data asynchronously after the first request.
- Cross-browser validation. The experience must work across Chromium, Firefox, and WebKit.
- Business-critical workflows. A failure here directly affects revenue or customers.
What you gain from running Playwright scripts in LogicMonitor
You test from where your users are. LogicMonitor Digital Experience runs your scripts across a global network of thousands of monitoring agents, spanning last-mile, backbone, wireless, cloud, and edge providers. That outside-in view shows how your site performs from the places your users connect from.
You can automate a full browser transaction with only a few lines of code. Whether you’re checking a product search or a login flow, you script the steps once. Then you run them on a schedule across the agent locations you choose.
Playwright assertions confirm exactly what matters. Methods like toHaveURL(), toBeVisible(), and toHaveText() check that the right page loaded and the right elements appeared. A passing test then reflects a genuinely working experience.
You can also see where a slowdown starts. Playwright wait methods such as waitForSelector and waitForResponse handle asynchronous content, so tests stay reliable under real conditions.
Platform tracepoints and indicators add depth. Tracepoints mark meaningful moments in a transaction, such as when a page becomes interactive. Indicators capture custom signals you define, so you can see which step slowed and why.
The integration also adds helpers that make production monitoring safer and easier to organize. You can store credentials securely rather than hard-coding them. You can also reuse global variables across tests and group related steps into named stages that map to a real journey.
Finally, you get multi-browser coverage. Paired with real user monitoring (RUM), it shows how each browser renders your pages while real user data confirms what people actually experience.
How Playwright monitoring works
The workflow moves from writing a test to acting on what it finds:
- Record, write, or import a Playwright script for the journey you want to watch.
- Schedule it to run from the agent locations that match your users.
- Capture step-level metrics for each action and assertion.
- Alert on failures and on degradation before users feel it.
- Correlate the results with your broader observability data.
You can import Playwright scripts from any environment, and recording provides a quick starting point, so building a monitor does not have to mean writing a complex script from scratch.
Here’s how this works in practice. A checkout synthetic test begins failing from several regions. LogicMonitor’s platform identifies the affected locations and the exact transaction step where the failure occurs.
Teams can then use LogicMonitor’s broader observability data to investigate what may be causing the issue, such as an origin-service slowdown, DNS problem, CDN disruption, or failing dependency. By bringing user-facing performance data together with infrastructure and cloud telemetry, LogicMonitor helps teams move from detecting an issue to understanding the systems behind it.
This user-to-code view gives teams the context they need to troubleshoot faster, reduce blind spots, and determine whether the problem is isolated to a specific region, provider, service, or application component.
Real-world examples
These two e-commerce scenarios show Playwright synthetic monitoring in practice.
Product search and wishlist
This test searches for a product, opens the product page, and adds the item to a wishlist. It then asserts that the item appears in the wishlist, which confirms the full path works. The scenario mirrors everyday tasks: navigating, clicking, and verifying results.
const { test, expect } = require('@playwright/test');
test('Product search and wishlist', async ({ page }) => {
await page.goto('https://www.example-store.com');
// Search for a product
const search = page.getByRole('searchbox', { name: 'Search' });
await search.fill('sofa bed');
await search.press('Enter');
// Confirm the results loaded
await expect(
page.getByRole('heading', { name: /results for "sofa bed"/i })
).toBeVisible();
// Open the first result and add it to the wishlist
await page.getByRole('link', { name: /sofa bed/i }).first().click();
await page.getByRole('button', { name: 'Add to wishlist' }).click();
// Verify the item reached the wishlist
await expect(page.getByText('Added to your wishlist')).toBeVisible();
});Cart checkout flow
This test signs in with securely stored credentials rather than hard-coded values, adds a product to the cart, and steps through checkout. Assertions on the checkout page confirm the order summary and totals look correct. If any step fails, the platform alerts you.
test('Cart checkout flow', async ({ page }) => {
// Sign in using credentials stored securely in the platform, not hard-coded
await page.getByRole('button', { name: 'Sign in' }).click();
await page.getByLabel('Email').fill(process.env.STORE_USERNAME);
await page.getByLabel('Password').fill(process.env.STORE_PASSWORD);
await page.getByRole('button', { name: 'Log in' }).click();
// Add a product to the cart
await page.goto('https://www.example-store.com/product/sofa-bed');
await page.getByRole('button', { name: 'Add to cart' }).click();
// Proceed through checkout
await page.getByRole('link', { name: 'Cart' }).click();
await page.getByRole('button', { name: 'Checkout' }).click();
// Confirm the checkout page loaded before payment
await expect(page).toHaveURL(/.*checkout/);
await expect(
page.getByRole('heading', { name: 'Order summary' })
).toBeVisible();
});Both examples show how to script real user interactions and verify each outcome. Whether you’re logging in, adding an item to a cart, or completing a purchase, Playwright and LogicMonitor’s Synthetics and Internet Performance Monitoring capabilities provide evidence that each step works.
Getting started
Getting started takes a Playwright script, or an existing test you can import. From there, the steps are straightforward:
- Import or paste your script, or migrate an existing test with minimal changes.
- Store any credentials securely instead of writing them into the script.
- Choose the agent locations that reflect where your users connect from.
- Set a schedule that matches how often the workflow matters.
- Configure alerts for outright failures and for gradual degradation.
- Maintain tests with stable selectors, sensible retries, and clear timeouts.
Because you run scripts directly in the platform, most existing Playwright tests move over with little rework, so you can start monitoring quickly.
Put your Playwright tests to work around the world
Turn your existing browser tests into synthetic monitoring with LogicMonitor Digital Experience. Catch broken user journeys before your customers do.
What is the difference between Playwright synthetic monitoring and a basic uptime check?
A basic uptime check confirms that a URL responds, but it cannot validate multi-step journeys like login or checkout. Playwright synthetic monitoring runs a full browser transaction on a schedule, verifying each click, page, and assertion. That way a passing test reflects a genuinely working experience for your users.
Do I need to rewrite my existing Playwright tests to run them in LogicMonitor?
Most existing Playwright tests move over with little rework. You can import or paste your script, store credentials securely instead of hard-coding them, and start monitoring quickly. Running scripts directly in the platform keeps testing and monitoring consistent.
Which browsers does Playwright synthetic monitoring support?
It provides multi-browser coverage including Chrome and Edge. Paired with real user monitoring, it shows how each browser renders your pages while real user data confirms what people actually experience.
