Every API in your stack deserves to be monitored, not just the critical ones.
LogicMonitor gives you coverage across availability, latency, errors, and payload correctness, with the context to act fast when something breaks.
What is API monitoring?
API monitoring is the continuous practice of testing and measuring the availability, performance, and correctness of APIs in production. It involves checking that endpoints respond within expected latency windows, return correct status codes, deliver valid payloads, and remain accessible from the locations your users depend on.
What is the difference between API monitoring and API testing?
API testing is typically performed before deployment to verify that an API behaves correctly against its specification. API monitoring is continuous and runs in production, verifying that the API continues to behave correctly under real traffic conditions, real infrastructure, and real user load. Testing catches defects; monitoring catches regressions and degradation.
How do I monitor a third-party API my application depends on?
Use synthetic monitoring to make scheduled requests to the third-party API from outside your own infrastructure, mirroring what your application experiences. Track response time, availability, and payload structure. Set alerts on degradation so you know about third-party issues before your own error rates rise. This gives you data to inform SLA conversations with the vendor.
What does an effective API monitoring dashboard show?
A well-designed dashboard shows real-time and historical availability, latency trends (average, p95, p99), error rate by endpoint, request throughput, and geographic availability if you test from multiple locations. Effective dashboards surface anomalies and correlate metric changes with deployment events, not just static numbers.
