Monitoring tells you something broke. LogicMonitor tells you why.
Get metrics, logs, and traces in one platform, with the high-cardinality data your team needs to diagnose distributed failures fast.
What are the three pillars of observability?
The three pillars are metrics, logs, and traces. Metrics provide aggregated, time-series measurements of system behaviour. Logs provide detailed, timestamped records of individual events and errors. Traces show the path of a request across distributed services and components. All three are required to diagnose failures in complex environments; any one pillar alone leaves critical blind spots.
Is API observability the same as API monitoring?
No. Monitoring tells you when something is wrong by alerting on known conditions. Observability tells you why by giving you enough data to ask and answer questions about system behaviour, including failure modes you have never seen before. Observability enables debugging; monitoring enables alerting. Teams need both working together.
What is high cardinality data and why does it matter for observability?
High cardinality data contains many unique values per field: for example, individual user IDs, request IDs, or specific endpoint paths. High cardinality is what makes observability powerful: it allows you to filter and drill into specific requests, users, or services during an incident rather than looking at aggregated averages that obscure the problem.
How do distributed traces help debug API failures?
A distributed trace records the full journey of a request as it passes through every service, database call, and external dependency in your system. When a failure occurs, the trace shows you exactly where latency was introduced or where an error originated, even across dozens of microservices. Without traces, you see that something failed; with traces, you see precisely where and why.
