Test your APIs before production. Monitor them relentlessly after.
LogicMonitor closes the loop between performance testing and production monitoring, so you know exactly how your APIs behave under real-world load.
What is the difference between load testing and stress testing?
Load testing applies a target level of expected or peak traffic to measure how an API performs under normal operating conditions, validating that you meet performance targets. Stress testing pushes the API beyond expected capacity to find the breaking point and understand failure behaviour. Load testing tells you if you meet your SLA; stress testing tells you what happens when you exceed it.
How much load should I simulate in an API performance test?
Start with expected average traffic, then test at peak load, then at 2–3x peak load as a safety margin. Use real traffic profiling data (endpoint distribution, request sizes, authentication patterns) rather than synthetic uniform load. Unrealistic test traffic gives false confidence. If you have seasonal peaks, test at those levels specifically.
How do I include authentication in API performance tests?
Pre-generate authentication tokens or API keys before the test run rather than authenticating during the test, to avoid skewing latency results with auth overhead and prevents overloading your auth service. For OAuth flows, generate token pools in advance and ensure tokens have a TTL long enough to last the duration of the test.
Should API performance tests run in CI/CD pipelines?
Yes, integrating lightweight performance tests into CI is one of the highest-leverage places to catch regressions at the code change level. Run smoke-level load tests on key endpoints in every pipeline. Run full soak and stress tests in a pre-production environment on a scheduled basis or before major releases, where longer runtimes are acceptable.
