Catch API performance degradation before users notice it.
LogicMonitor tracks latency percentiles, correlates performance trends with deployments, and alerts on meaningful deviations rather than just hard thresholds.
What causes sudden API performance degradation?
Common causes include a code deployment introducing a slower algorithm or database query, increased traffic exceeding capacity, a slow downstream dependency, infrastructure changes such as VM resizing or network route changes, or resource exhaustion such as connection pool limits or memory pressure. Correlating performance data with deployment events is the fastest way to narrow down root cause.
How is API performance monitoring different from load testing?
Load testing is performed pre-production to understand how an API behaves under controlled, simulated load. Performance monitoring is continuous and observes real production traffic. Load testing validates capacity; performance monitoring protects it by detecting degradation as it develops, before it reaches the threshold where users notice.
What is a reasonable API response time target?
Common guidelines suggest under 100ms for simple read operations, under 300ms for more complex queries, and under 1 second for operations involving significant computation or external calls. Google’s research suggests 200ms as the threshold beyond which users begin to notice latency in interactive applications. Define targets based on your specific use case and user expectations, then monitor against them.
How do you detect gradual performance degradation in production APIs?
Monitor p99 latency over days and weeks rather than just minutes; soak testing under sustained load and long-running trend analysis are the primary methods. Alerting on week-over-week trend increases, rather than just threshold breaches at a single point in time, catches slow deterioration before it becomes a production incident.
