Calling something a REST API when it is just a web API is not a semantic argument. It shapes every architectural decision that follows.
Web APIs are any interface accessible over HTTP; REST APIs are a specific architectural style with six defining constraints that most self-described REST APIs do not fully implement.
The distinction matters for caching, statelessness, and uniform interface design. Teams that blur the line build systems that are harder to scale and maintain.
SOAP, GraphQL, gRPC, and REST are all web APIs but with fundamentally different design philosophies and trade-offs.
Before choosing your API style, define your constraints first: if statelessness, cacheability, and a uniform interface fit your use case, REST earns its name.
In modern web and app development, Application Programming Interfaces (APIs) are the backbone of systems, applications, and platforms. Among the numerous types of APIs available, REST and Web APIs are terms that developers often encounter.
Web API vs. REST API—is there a difference? This guide delves into these concepts to help developers decide which API protocol makes sense for their specific use cases.
Summary of differences: Web API vs. REST API
| Difference | Web API | REST API |
| What they are | Web APIs encompass any API using HTTP or HTTPS. All REST APIs are Web APIs, but not all Web APIs are RESTful. | REST APIs are Web APIs that follow specific architectural principles like statelessness and client-server architecture. |
| State | Technically, they can be stateless or stateful. | Statelessness implies that between sessions of API invocation, the server that hosts the program doesn’t need to ‘remember’ or hold any information between sessions to perform the appropriate action. |
| When to choose | Non-RESTful Web APIs are used for stateful operations, ACID-compliant transactions with a web server, and working with legacy systems. | Statelessness is the main consideration when choosing RESTful APIs over non-RESTful APIs. |
| Common use case | Many legacy systems, especially those that communicate with systems such as hardware or IoT devices, also use non-REST-based APIs. | RESTful APIs are often used in web services that require standardized communication and interoperability between different systems. |
What are web APIs?
A Web API is an interface that allows applications to interact with each other over HTTP or HTTPS protocols. It provides a set of rules and protocols for building and interacting with software applications. There are many types of Web APIs like REST, SOAP, and GraphQL (see below). The terms Web API and REST API are sometimes used interchangeably, but it is important to note that all Web APIs are not REST APIs. Technically, Web API is an umbrella term for many different types of APIs that use HTTP as the communication protocol—as summarized in the table below.
| Web API type | Description | Type |
| REST | Follows REST architecture | RESTful |
| SOAP | Utilizes XML, strict standards | Non-RESTful |
| GraphQL | Flexible query language | Non-RESTful |
Let’s explore these common types in detail below.
REST API
A REST API is a type of Web API that adheres to the principles of REST. REST principles emphasize statelessness, easy-to-use and self-descriptive messages, and a layered structures to facilitate the caching of components to help scaling. We delve into the principles in a later section of this article.
Here’s a Python code example of a RESTful Web API.
from flask import Flask, jsonify
app = Flask(__name__)
@app.route('/users', methods=['GET'])
def get_users():
return jsonify({'users': ['Alice', 'Bob']})
if __name__ == '__main__':
app.run()This code follows REST principles as it uses HTTP methods and stateless communication.
SOAP API
Simple Object Access Protocol (SOAP) is a protocol for exchanging structured information to implement web services. Unlike REST, SOAP relies on XML-based messaging and strict standards.
Here’s a Python code example of a SOAP Web API:
from spyne import Application, rpc, ServiceBase, String
from spyne.protocol.soap import Soap11
from spyne.server.wsgi import WsgiApplication
class HelloWorldService(ServiceBase):
@rpc(String, _returns=String)
def say_hello(ctx, name):
return f"Hello, {name}"
application = Application([HelloWorldService], 'spyne.examples.hello.soap',
in_protocol=Soap11(validator='lxml'),
out_protocol=Soap11())
wsgi_application = WsgiApplication(application)GraphQL API
GraphQL API
GraphQL is a query language for APIs that provide a more flexible and efficient approach to data retrieval. REST exposes multiple endpoints for different resources, but GraphQL exposes a single endpoint for all interactions. This single endpoint allows clients to request exactly the data they need, down to individual fields on objects.
In REST, you would typically have to make multiple requests to different endpoints to gather related data. For example, if you wanted to get information about a book and its author, you might first fetch the book details from a /books/{id} endpoint and then fetch the author details from an /authors/{id} endpoint. In GraphQL, you can fetch all this related data in a single query, specifying exactly what you need.
Suppose you have a GraphQL API that provides information about books and authors. You want to fetch a book’s title and its author’s name. Here’s a GraphQL query that does just that.
query {
book(id: "1") {
title
author {
name
}This query asks for the book with id of “1”, and for that book, it requests the title and the name of the author.
On the server side, you might handle this query with a resolver function written in Python using a library like Graphene. Here’s a simple example:
import graphene
class Author(graphene.ObjectType):
name = graphene.String()
class Book(graphene.ObjectType):
title = graphene.String()
author = graphene.Field(Author)
class Query(graphene.ObjectType):
book = graphene.Field(Book, id=graphene.String())
def resolve_book(self, info, id):
# Fetch the book from your data source using the provided id
book_data = get_book_by_id(id)
return Book(title=book_data['title'], author=Author(name=book_data['author_name']))
schema = graphene.Schema(query=Query)This code defines the GraphQL types Author and Book and a query that allows you to fetch a book by its id. The resolve_book function is responsible for actually fetching the data; in a real-world application, you would implement get_book_by_id to retrieve the data from your database or other data source.
Architecture: Non-RESTful web API vs. REST API
The key difference between REST and Non-REST APIs is how they process data. Let’s explore the details below.
REST APIs
RESTful APIs allow easy data ingestion through standard HTTP methods like GET, POST, PUT, and DELETE. This standardization makes it easier to integrate with various platforms and tools.
Stateless
Statelessness ensures the server does not need to retain information about the client’s state between requests. Each request from a client contains all the information needed to process it, simplifying data handling. Statelessness is the main design consideration for REST APIs— if the server doesn’t need to know or remember anything, then most likely, the best choice for your use case is a REST API.
Scalable
The stateless nature of REST allows for greater scalability, as you can easily add new instances without worrying about shared state. REST allows simple microservices deployed using AWS Lambda, GCP Cloud Functions, or Azure Functions to handle more than millions of requests per second with serverless technology.
Easy to use
The use of standard HTTP methods in RESTful APIs simplifies the process of sending and receiving data. For example, creating a simple API in Flask or with a package like FastAPI can be done in less than 15 lines of code with only one import statement. This simplicity makes it easier for developers to get started and facilitates collaboration among team members. When everyone is on the same page about how data should be ingested and processed, it accelerates the development cycle and helps to maintain code quality.
Non-RESTful web APIs
Non-RESTful APIs, such as SOAP, may require specific protocols or standards for data ingestion.
Complexity
Non-RESTful APIs like SOAP may require specific headers and XML-based request bodies, adding complexity to data ingestion.
Statefulness
Some non-RESTful APIs maintain state between requests, which complicates data handling but may be necessary for specific use cases like web sockets deployed for services like data streaming or gaming applications.
Protocols like SOAP often include built-in security standards, such as WS-Security, which can be beneficial for secure data transmission. Security is one of the reasons nowadays that developers choose a non-RESTful web API over a REST.
Flexibility
Non-RESTful APIs offer more flexibility in handling complex operations and transactions, particularly in enterprise environments.
API Performance: Non-RESTful web API vs. REST API
Apart from architecture, performance is a key consideration in the non-RESTful Web API vs. REST API debate.
REST APIs
REST APIs often perform better due to their stateless nature and reliance on standard HTTP methods. They typically use JSON, which is generally more lightweight than XML in SOAP and leads to faster data transmission and processing. They also leverage HTTP caching mechanisms to improve response times. Clients or intermediate proxies can cache responses for faster retrieval.
The stateless nature of REST reduces server overhead, as there’s no need to manage client sessions. This can lead to better performance and scalability. As mentioned before, serverless technology dramatically decreases the costs of performant REST APIs.
Non-RESTful APIs offer specialized performance features tailored to specific use cases. Some non-RESTful APIs allow batching multiple requests into a single HTTP request, reducing overhead and improving performance. They may also support specific compression algorithms that reduce transmitted data’s size and improve transmission speed. You can also design them with specific performance optimizations tailored to the unique requirements of a particular system or use case.
For example, compared to REST, the level of granularity GraphQL provides is particularly useful for reducing over-fetching and under-fetching of data and improving web application performance. Clients can request exactly the data they need, nothing more, nothing less.
Additionally, GraphQL APIs are strongly typed, making it easier to validate queries and responses. GraphQL provides a powerful alternative to REST for various use cases, especially those requiring complex queries and multiple related resources, by offering a more flexible query language.
Use cases: Non-RESTful web APIs vs. REST API
It can be challenging to choose a specific API type as different use cases have different nuances to consider. We have summarized suggestions in the table below.
REST APIs
| Use Case | Explanation |
| Stateless Applications | REST simplifies scaling and allows for easy caching, making it ideal for stateless operations where each request contains all the information needed to process it. |
| Scalable Systems | The stateless nature of RESTful APIs provides for greater scalability, as new instances can be easily added without worrying about shared state. |
| Interoperable Solutions | RESTful APIs use standard HTTP methods, making them highly interoperable with various systems and programming languages. |
| Simple CRUD Operations | RESTful APIs are well-suited for simple Create, Read, Update, Delete (CRUD) operations, as they align with standard HTTP methods (POST, GET, PUT, DELETE). |
| Publicly Exposed APIs | REST’s simplicity and standardization may make it a good choice if you plan to expose your API to various clients. |
| Stateful Operations | Non-RESTful APIs are suitable for stateful tasks where the server must retain information about the client’s state between requests. This can be useful for complex transactions and workflows. |
| Complex Queries | Non-RESTful APIs like GraphQL allow clients to request exactly the data they need, enabling more complex and optimized queries. |
| Secure Transactions | Protocols like SOAP include built-in security standards, making them suitable for secure transactions and data transmission. |
| Integration with Legacy Systems | Non-RESTful APIs may be a better fit when integrating with legacy systems that require specific protocols or data formats. |
| Real-time Communication | For real-time communication and updates, non-RESTful solutions like WebSockets may be more appropriate, as they allow for continuous two-way communication between the client and server. |
What to look for in Web API performance monitoring
Monitoring the performance of both RESTful and non‑RESTful web APIs is essential for maintaining a positive digital user experience. To do this well, you need capabilities that extend beyond basic uptime checks and simple response‑time metrics.
End‑to‑end visibility across the full path
A modern solution should give you insight into every component a request traverses between the end user and the API, including:
- DNS resolution for the API endpoint address
- Content delivery networks (CDNs) serving API responses
- Internet service providers and intermediate networks
- Gateways, microservices, and downstream dependencies behind the API
This holistic view helps you understand whether a slowdown is caused by your own services or by third‑party infrastructure you rely on.
Monitoring from the user’s perspective
To accurately reflect real experience, look for tools that can:
- Combine real‑user monitoring (RUM) with synthetic monitoring (emulated API transactions)
- Run tests from multiple geographies, networks, and device types (desktop, mobile, etc.)
- Continuously validate that APIs remain responsive under different conditions
For example, an API call can be delayed by slow DNS resolution, a degraded CDN edge, or routing issues in one of the ISPs along the path—not just by application code.
Backend and dependency awareness
Effective API performance monitoring should also illuminate what happens on the server side:
- Tracing across upstream and downstream services to reveal dependencies
- Visibility into slow or inefficient code paths that affect API latency
- Context about how changes in one service impact overall transaction performance
This makes it easier to distinguish network‑level problems from application‑level bottlenecks.
Key capabilities for DevOps and SRE teams
When evaluating solutions, teams typically need the ability to:
- Capture availability, latency, and custom KPI metrics for regression and long‑term trend analysis
- Execute API transactions for functional testing and validate responses against expected payloads
- Assure service delivery across a complex mesh of endpoints, microservices, and gateways for data integrity
- Monitor the complete transaction path, including public‑internet components that often get blamed on the SaaS provider
- Detect and manage API incidents in real time, before users raise tickets or complain about performance
Support for open standards such as OpenTelemetry also helps avoid lock‑in to proprietary instrumentation and makes it easier to correlate API telemetry with other observability data
Conclusion
Web APIs can be both RESTful and non-RESTful. There are more types of non-RESTful APIs, and while RESTful APIs are the most common approach, being prepared to utilize and understand both is essential for developers. Choosing between non-RESTful Web API vs. REST API depends on the specific requirements of the application and the use cases it needs to support.
Most modern applications have RESTful APIs used in some capacity, so if you are new to learning about API deployment and development, this is the most logical place to start. Additionally, with the improvement of serverless deployment/hosting technologies, REST APIs are frequently the most cost-effective and lean approach to development, offering simplicity, scalability, and standardization. Nonetheless, non-RESTful Web APIs may provide more flexibility, security, and tailored functionality for complex or specialized tasks.
From REST to GraphQL to gRPC, monitor every API in your stack.
LogicMonitor gives you consistent visibility across every API style and protocol, so the architecture decision you make today never becomes a monitoring gap tomorrow.
Is every REST API a web API?
Yes, all REST APIs communicate over HTTP/HTTPS and are therefore web APIs. But not every web API is a REST API. SOAP APIs, GraphQL APIs, gRPC APIs, and WebSocket APIs are all web APIs that do not follow REST’s architectural constraints. REST is a specific subset of the broader web API category, not a synonym for it.
What makes a REST API truly RESTful?
A truly RESTful API adheres to all six of Roy Fielding’s architectural constraints: client-server separation, statelessness, cacheability, a uniform interface, a layered system, and optionally code-on-demand. In practice, most APIs described as REST implement only some of these constraints (particularly statelessness and a uniform interface) while ignoring cacheability and HATEOAS entirely.
Why does the distinction between web API and REST API matter in practice?
It shapes architectural decisions. If you are building a REST API, you design for statelessness, cacheability, and a uniform interface, with significant implications for scalability and client design. If you actually mean an HTTP-based API, those constraints may be unnecessary and imposing them adds complexity. Being precise about what you are building prevents costly design mismatches later.
What is SOAP and is it still relevant?
SOAP (Simple Object Access Protocol) is a web API protocol that uses XML messaging and a formal WSDL contract. It predates REST and is less common in new development. However, it remains widely used in enterprise environments (particularly financial services and healthcare), where its strict typing, built-in error handling, and WS-Security standards make it appropriate for legacy system integration.
