SaaS monitoring that works starts with testing from your users’ perspective, not your data center’s.
Synthetic tests and real user monitoring fill each other’s blind spots. Synthetic catches infrastructure issues before users notice; RUM reveals the browser quirks, geographic slowdowns, and mobile frustrations that scripts can’t simulate.
API health checks and distributed tracing cut through microservice complexity. Track response time baselines, validate payloads, and map dependencies across services, not just whether an endpoint returns 200 OK.
Smart alerting with clear ownership and runbooks reduces mean time to resolution. Every alert should name who owns it, what to check first, and how to escalate.
Start with synthetic tests on your highest-traffic user flows, layer in RUM for geographic and device coverage, then build alerting rules based on actual impact thresholds rather than arbitrary numbers.
SaaS Application Monitoring
SaaS applications introduce monitoring complexity that internal infrastructure tools weren’t built to handle. Performance issues often originate outside your servers, in CDNs, third-party services, regional network paths, or user browsers, and standard infrastructure monitoring doesn’t capture them.
This guide explains how to set up SaaS application monitoring that preemptively detects issues and quickly identifies possible causes. The guide focuses on application performance, availability, and user experience over security. You’ll find specific steps for catching problems early, measuring what matters, and keeping monitoring manageable as your application grows.
Summary of key SaaS application monitoring best practices
| Best practices | Description |
| Implement synthetic monitoring. | Simulate user interactions to proactively detect issues. |
| Use real users and conduct smoke tests. | Collect data from user interactions in real time to gain insights into performance. |
| Track device diversity. | Capture real user experiences on handheld devices using mobile RUM. |
| Ensure API health and implement distributed tracing. | Continuously test and monitor API endpoints and track requests as they move through different application components. |
| Establish SLOs and Metrics. | Define performance indicators aligned with business goals and monitor the related metrics. |
| Automate alerts and reporting. | Configure alerts to notify relevant teams when something goes wrong. |
| Integrate monitoring with DevOps. | Integrate monitoring into continuous integration and deployment pipelines. |
| Monitor third-party dependencies. | Keep track of external services or dependencies and ensure they’re secure and up-to-date. |
Synthetic tests run scripted checks of your primary user flows on a set schedule, catching availability and performance issues before users encounter them.
The key to synthetic testing is testing from diverse geographic locations where your customers reside. If most of your customers are in Europe but you’re only testing from US data centers, you’re missing the complete picture. LogicMonitor Digital Experience provides global vantage points for synthetic testing from locations worldwide, letting you prioritize the regions that matter most to your user base.
Set these tests up for your primary user flows. If, for example, your application is a CRM, that would mean testing things like user login and authentication, creating contacts, running reports, or whatever your users do most often. Run them at different times too. What works fine at 3 AM might experience much larger latencies during peak hours.
Synthetic tests are great, but sometimes, you can’t account for every possible scenario a user might experience. In practice, users may have slow connections, weird browser versions, or be trying to load your app on their phone while on the train.
Understanding and improving application performance requires insights from both real user monitoring (RUM) and synthetic monitoring. Relying on just one source leaves you with an incomplete picture. RUM reveals how actual users experience your website, while synthetic monitoring proactively uncovers potential problems before they impact users.
You might think your application performs well because your synthetic tests look good, but RUM data might show that users in South America are consistently having a poor experience. Or, everyone using Safari is hitting JavaScript errors that don’t appear in your Chrome-based tests.
Keep an eye on:
- How long pages take to load
- JavaScript errors and execution timing
- Network timing issues
- Errors users hit but don’t report
- Browser and device patterns
- Geographic performance variations
- User paths that your synthetic tests missed
- Mobile-specific metrics like app load time and network transitions
Smoke tests act as a safety net after deployments, catching obvious breakages before users encounter them. They’re quick-running checks of the core features that ensure nothing obvious is broken. For example, can users log in, create records, and access main features? If these fail, something is broken, and your team should be alerted immediately.
The key to smoke tests is to keep them focused on reliability across environments and devices. If your SaaS application supports both desktop and mobile access, plan tests to cover critical functions in both environments to ensure consistent reliability regardless of how users connect. Test the critical features, make the tests robust, and ensure failures are evident and actionable. If a smoke test fails, the on-call team should know immediately what broke and where to start.
LogicMonitor offers mobile real user monitoring with OpenTelemetry support, giving you clear visibility into how your mobile users experience your app. The platform also helps track frustration metrics like rage clicks (when users repeatedly click the same spot in frustration), dead clicks (clicks that trigger no response), and erratic cursor movements, all of which are telltale signs of users struggling with your interface.
APIs can degrade performance or return invalid data without throwing errors, so problems often go unnoticed until users complain. Monitor how often your APIs fail entirely and when response times drop below useful thresholds.
API monitoring has become more complex with microservices. It’s no longer enough to check if an endpoint returns 200 OK. Monitoring teams must verify response times, validate payload accuracy, and monitor API performance across different regions.
LogicMonitor’s API monitoring capabilities let you validate your APIs’ functionality and performance across multiple geographic locations, detecting issues that might only appear in specific regions or under certain network conditions. The platform’s ability to execute multi-step API transactions lets you test complex user flows that span multiple endpoints, which is crucial for modern SaaS applications.
Smart API monitoring requires you to:
- Check response times from multiple locations
- Verify that the content makes sense, not just the status code
- Look for patterns, whether slowdowns cluster around peak hours or specific regions.
- Make sure your third-party APIs aren’t letting you down.
Distributed tracing
Pinpointing the problem when debugging a “slow app” can be difficult. Distributed tracing is a technique that lets you follow a specific request as it passes between services, seeing exactly where delays occur. You can use it to identify scenarios such as an API responding quickly but waiting on a database query, or a third-party service consistently being slow to respond.
You must also know what “normal” looks like for your system. If an API endpoint usually responds in 100ms, a jump to 300ms is worth investigating, even though many monitoring systems would consider these values acceptable. Set your baselines based on actual usage patterns, not arbitrary numbers.LogicMonitor’s Internet Stack Map visualization brings this concept to life by providing a clear, interactive map of your entire Internet Stack, which is often hidden from traditional APM tools. You can see exactly how each component, from DNS and CDN to third-party services and client-side JavaScript, contributes to your application’s performance. The automatically generated maps also pinpoint performance bottlenecks across your applications and services for rapid troubleshooting.
Establish relevant SLOs and metrics
Service level objectives (SLOs) should be based on metrics that matter to your users and the overall user experience. Prioritize:
- How fast key actions feel to users (not just how fast they are)
- How often people experience errors when doing core actions
- Whether critical features are available when needed
- Response times for revenue-generating operations
Set realistic goals and refine them later. SLO targets should be stricter depending on the functionality’s importance. For example, payment processing should have more stringent SLOs than report generation.
The real value of SLOs comes from trending them over time. Growing variation in response times or inconsistent target attainment are early indicators of underlying problems before they become serious issues.
Review your SLOs regularly. What seemed important some time ago might not matter now, and new critical paths might have emerged. This is especially true if you frequently push updates, as new features often mean new things to monitor.
The real challenge with alerting is defining what “broken” means and building a strategy that surfaces what matters without burying your team in noise.
Smart alerting means:
- Clear severity levels that everyone understands
- Every alert has an owner
- Every alert provides enough context to start solving the problem (e.g., links to logs or dashboards)
- Pre-determined thresholds based on actual impact
- Well-defined escalation paths
The best alerts also include runbooks, which can act as simple instructions for what to check first. Something as simple as “Check X first, then Y; common causes are Z” can save precious minutes during an outage. Runbooks also mitigate knowledge silos, reducing the need for on-call experts.
Integrate monitoring with the DevOps process
Build monitoring into your development process from the start. Treat your monitoring configurations like code, version-controlled, reviewed, and deployed alongside your application. A monitoring-as-code approach means:
- Your monitoring setup is documented and traceable
- Changes get reviewed just like code changes
- You can roll back monitoring changes as needed
- New environments automatically get the proper monitoring
- Everyone can contribute to improving monitoring
Integrate monitoring into your CI/CD pipeline to verify it before pushing to production. Check that:
- New features have appropriate monitoring
- Alerts are configured correctly
- Dashboards are updated for new metrics
- Old monitoring that’s no longer relevant is removed
In many cases, CI/CD pipelines also include canary testing and monitoring. Spin up a container with the newest code and direct a small percentage of real traffic. If, after some time, this pod environment doesn’t trigger alerts, you can be more confident that the code is ready to go.
Third-party services can save you from building everything yourself, but each is a potential failure point. If dependencies fail, users experience your application as broken regardless of where the fault lies.
Dependency monitoring involves:
- Watching response times from third-party APIs
- Setting up fallback options where possible
- Keeping track of their uptime promises versus reality
- Understanding which services can fail without taking down your whole app
- Having plans for when critical services fail
It’s also wise to build circuit breakers into your app. If a third-party service is becoming a bottleneck, you can identify it and stop forwarding requests that are likely to continue failing. Cache what you can, gracefully degrade, and make sure you can deploy changes quickly if the service goes completely down.
Most importantly, track which features depend on which services. When something goes wrong, you want to immediately know which parts of your app might be affected. This dependency mapping is crucial for troubleshooting and planning future architecture changes.
For every third-party service your application depends on, make sure your team knows:
- How your app behaves if it’s slow
- How your app behaves if it’s down
- How to detect if it’s having problems
- What your options are when it fails
- How to contact their support (and their SLA for responses)
Internet Sonar uses a global intelligent agent network to provide real-time visibility into internet outages that could impact your application’s performance. This visibility data powers Internet Stack Map, which automatically creates visual representations of your application’s dependencies, including external services. When problems arise, you can quickly pinpoint the internal or external source and reduce your mean time to resolution (MTTR).
Last thoughts
Monitoring’s real value shows up months later when you’re trying to figure out why performance is worse than it used to be or whether that new feature helped. Keep the metrics that have proven useful. Drop the ones that create noise without leading to action.
Get your fundamentals working to catch critical issues in time and minimize their impact. Monitoring is a continuous practice. As your application changes, your monitoring should change with it. Use what you learn from incidents and user feedback to drive the next improvement.
Stop guessing where SaaS performance breaks down. See the full picture from user to code.
LogicMonitor Digital Experience connects synthetic monitoring, real user data, API health, and Internet dependency tracking in one platform, so your team can find and fix issues before users notice.
What’s the difference between synthetic monitoring and real user monitoring for SaaS applications?
Synthetic monitoring runs scripted tests that simulate user interactions from specific locations and devices on a set schedule. It catches infrastructure and availability issues proactively. Real user monitoring (RUM) collects performance data from actual user sessions, revealing problems tied to specific browsers, devices, geographies, or network conditions that synthetic scripts can’t predict. Most teams need both for complete coverage.
How do I set meaningful SLOs for a SaaS application?
Base your SLOs on metrics that directly affect user experience, like page load time for key actions, error rates on core workflows, and availability of revenue-generating features. Start with realistic targets informed by your current performance baselines, not arbitrary numbers. Make SLOs stricter for high-impact functionality (e.g., payment processing) and review them regularly as your application evolves.
How should I monitor third-party API dependencies in a SaaS application?
Track response times, error rates, and payload accuracy from multiple geographic locations. Build circuit breakers into your application so a failing third-party service doesn’t cascade into a full outage. Maintain a dependency map that links each external service to the features it supports, so when something breaks, your team knows exactly which parts of the app are affected and where to start troubleshooting.
How do I reduce alert noise without missing critical SaaS application issues?
Define clear severity levels tied to actual user impact, not arbitrary thresholds. Assign an owner to every alert and include enough context (links to dashboards, logs, runbooks) so the responder can act immediately. Set thresholds based on observed
