Effective incident management gives IT teams a consistent process to restore service, limit disruption, and improve future response.
Clear ownership and coordinated communication help teams make timely decisions during an incident.
Monitoring, observability, and dependency mapping reveal how failures move across applications, infrastructure, cloud platforms, and third-party services.
Metrics should show response quality, recovery capability, business impact, and recurring failures.
- LogicMonitor brings these capabilities together, helping IT teams connect operational context, incident response, observability, automation, and AIOps in one platform.
When an IT service fails, the quality of the response can determine how far the disruption spreads. To limit that impact, IT teams need actionable context, clear ownership, coordinated communication, and a defined path to restore service.
This guide covers the people, practices, metrics, and technology that help IT teams respond faster without losing control.
Incident Management Defined
In IT Service Management (ITSM), incident management is the process of identifying, assessing, and resolving unplanned interruptions or reductions in the quality of an IT service. It gives teams a consistent way to manage incidents from the moment they are reported until service has been restored.
IT Infrastructure Library (ITIL) defines incident management as the process of minimizing the negative impact of incidents by restoring normal service operation as quickly as possible. The focus is on reducing disruption for users and the business.
Incident management applies across ITSM, ITOps, CloudOps, digital services, and hybrid IT environments. It can be used for incidents involving applications, servers, networks, databases, cloud platforms, identity systems, employee devices, or external providers.
Modern incidents can cross several of these areas because digital services depend on interconnected systems. An application may rely on a cloud platform, network, database, identity provider, DNS service, or third-party API. When one dependency fails, the effects can spread to other services and users.
For example, an outage at an identity provider may prevent access to multiple applications, even when those applications are operating normally.
That’s why incident management means looking past the first alert or the most visible symptom. The incident owner needs to understand the affected service, its dependencies, its business impact, and which teams or providers must be involved in recovery.
IT Incident Definition and Examples
An IT incident is an unplanned interruption or reduction in the quality of an IT service that requires a response to restore normal operations. It may affect an entire organization, a specific team, individual users, or external customers.
Common examples include:
- An application outage
- Slow or degraded application performance
- Failed customer transactions
- An inability to access an account or system
- A network connection failure
- An unavailable cloud platform or third-party service
The table below shows how an incident differs from events, service requests, problems, planned changes, and security incidents.
| Term | Meaning | Example |
| IT incident | An unplanned interruption or reduction in service quality. | An application outage prevents customers from completing transactions. |
| Event or alert | A detected system change or notification that may require attention. | An alert reports unusually high application latency. |
| Service request | A routine request for access, information, or a standard service. | An employee requests access to an application. |
| Problem | The underlying cause of one or more incidents. | A database issue causes repeated outages. |
| Planned change | An authorized modification to an IT service or environment. | A software update unexpectedly causes an outage. |
| Security incident | A potential or confirmed threat to data or system security. | Unauthorized access makes a customer portal unavailable. |
The defining feature of an IT incident is its effect on service delivery. A technical issue becomes an incident when users, customers, or business operations experience an unacceptable loss of access, performance, or reliability.
Goals of Incident Management
Incident management has seven main goals:
- Restore service quickly and safely so users can return to normal work with minimal risk of further disruption.
- Limit customer and business impact by prioritizing incidents according to their effect on critical services and operations.
- Give one person clear ownership of coordinating the response and keeping it moving.
- Coordinate technical specialists and give stakeholders timely, consistent updates.
- Enforce Standards to create a consistent workflow to classify each incident, set its priority, assign the appropriate owner, and escalate it when necessary.
- Keep an accurate incident record of decisions, actions, evidence, communications, and recovery details.
- Prevent repeat failures by assigning follow-up work, improving procedures, and addressing underlying causes after service is restored.
The Incident Management Process, Step by Step
The process runs in nine steps, starting with detection and ending with a review of the outcome.
- Detect the incident when monitoring, logs, user reports, or vendor notifications show a service is unavailable or degraded.
- Log it in a central record with the affected service, detection time, reported impact, available evidence, and assigned owner.
- Categorize it by service or technical area, so it reaches the right specialists and matches up with similar incidents.
- Prioritize and triage it by weighing severity, urgency, affected users, service importance, business impact, workarounds, and the risk of further disruption.
- Assign an owner who coordinates work, keeps the record, tracks progress, and manages communication, escalating for access, specialist expertise, management authority, or provider support.
- Investigate and diagnose using telemetry, recent changes, service dependencies, runbooks, and past incidents to find the likely cause and safest recovery option.
- Resolve the issue with a fix, rollback, workaround, or fallback procedure, then verify service health and key user workflows.
- Close the incident once the resolution is documented and affected stakeholders have an update.
- Review the timeline, technical evidence, decisions, communication, and recovery to see what worked and where delays occurred.
Work that’s still pending at closure gets its own record. A problem record covers investigation of the underlying cause, and a change record manages a planned system update, each with an owner and due date. Findings from the review then go into better alerts, runbooks, dependency records, and recovery procedures.
Roles and Responsibilities in Incident Management
In most organizations, the IT operations team owns incident management and brings in other roles as an incident’s scope and severity require:
- Service desk: Takes incident reports, creates records, and handles initial assessment and support.
- Incident owner: Coordinates the incident, tracks progress, and keeps the response moving.
- Technical specialists: Investigate the issue and carry out recovery actions.
- Service owner: Represents the affected service and helps judge business impact and recovery priorities.
- Incident manager: Oversees the process, escalation, communication, and resource coordination.
- Incident commander: Leads the response to a major incident and directs decisions across teams.
- Communications lead: Sends timely, consistent updates to users, leaders, and stakeholders.
- Vendor or third-party contact: Coordinates support when an external provider or dependency is involved.
Set the communication cadence at prioritization. Each update should name the affected service, current impact, actions underway, available workarounds, and the time of the next update. The incident owner or communications lead keeps internal teams, leaders, customers, and affected providers working from the same information.
On smaller incidents, one person may cover several roles. A major incident needs clearly assigned responsibilities, so technical teams can focus on recovery while the incident owner or commander coordinates the overall response.
Severity and Prioritization in Incident Management
Severity and priority help IT decide how serious an incident is and what to address first. Severity describes the scale and consequences of the disruption. Priority sets the response time, the order of work, and the resources assigned.
Common Incident Severity Levels
Severity scales vary by organization. Some use three levels and others use four or five, depending on their services and business risks. A common five-level model looks like this:
- SEV-1 (Critical or blocker): A core system is completely unavailable, an active data breach is underway, or a catastrophic failure has stopped critical business operations. It requires an immediate major incident response involving incident leadership, technical specialists, and stakeholder communication.
- SEV-2 (Major): A key service or feature has failed or degraded for a large group of users or an important business unit. The incident needs urgent investigation, escalation, and regular progress updates.
- SEV-3 (Moderate): The incident causes limited performance or functional problems, but core workflows continue operating, and a workaround may be available. IT staff can usually handle it through normal support channels, depending on its urgency.
- SEV-4 (Low): The issue has minimal user or business impact, such as a minor functional defect, cosmetic problem, or uncommon UI error. The service owner can schedule the work through the normal backlog.
- SEV-5 (Informational): The event has negligible service impact and doesn’t require an active incident response. IT may record it for monitoring, maintenance, or later analysis. Feature requests should usually enter the product or service-request backlog rather than the incident process.
Some organizations use L1, L2, and L3 instead of SEV labels. In this model, L1 may be called a blocker and usually represents the highest level of impact. Since naming conventions differ, every severity level should include specific qualifying conditions and the response it activates.
Factors That Determine Incident Priority
Severity is one input to priority. During triage, weigh it alongside these factors:
- How many users, customers, locations, or services are affected
- How important the affected service is to business operations
- How urgently the organization needs to restore the service
- Whether the incident could spread to connected services
- How much revenue or employee productivity is at risk
- Whether the incident creates a security or compliance concern
- Which SLA, SLO, or customer commitments apply
- Whether a workaround can preserve essential functions
The assigned priority should define the acknowledgment target, escalation path, communication schedule, and technical or leadership resources required.
Incident Management vs. Related IT Practices
Several related practices can run during the same disruption as incident management, and each one handles a different type of work.
| Practice | Primary Question It Answers |
| Incident management | How should the organization manage this incident from beginning to end? |
| Incident response management | Who needs to act now, what should they do, and who can approve the next action? |
| Problem management | Why did this failure occur, and how can we prevent it from returning? |
| Change management | How can we introduce this production change with an acceptable level of risk? |
| Incident response | What technical actions will contain the disruption and restore service? |
Incident Management vs. Problem Management
An incident can be resolved before anyone knows the underlying cause. IT might restore an application by moving traffic to a healthy environment. Once recovery is confirmed, the incident closes, and problem management continues separately to investigate why the original environment failed and track the permanent correction.
Incident Management vs. Incident Response Management
During a major outage, application, infrastructure, network, and vendor specialists may work on different issues at the same time. Incident response management coordinates that active work. It assigns ownership, manages escalation and approvals, sets the communication cadence, and verifies recovery.
Incident management wraps the wider lifecycle around that response, with logging and prioritization before it and closure, review, and follow-up after it.
Which Technologies & Tools Support Incident Management?
These tools help teams detect incidents, understand their impact, coordinate the response, and restore service:
- Monitoring and observability platforms: Detect service degradation across infrastructure, applications, networks, and cloud environments.
- SIEM and Security Analytics: These tools collect and correlate security logs, detect suspicious activity, and provide evidence for investigating and managing security incidents.
- ITSM and ticketing systems: Record incidents, assign ownership, track progress, and document resolutions.
- Service topology and dependency mapping: Show how applications, infrastructure, and external services connect.
- Logs, metrics, and traces: Provide evidence for investigating symptoms, scope, and likely causes.
- Runbooks and knowledge bases: Provide documented procedures for handling recurring issues.
- Collaboration and communication tools: Help teams coordinate work and keep stakeholders informed.
- Workflow automation: Automates repeatable tasks such as routing, notifications, enrichment, and recovery procedures.
- AI-assisted investigation and remediation: Helps teams speed up incident response, investigate likely causes, and support AI-driven incident management.
Which Incident Management Metrics Matter?
The most helpful incident management metrics are those that show more than how fast IT staff handled an incident. Assess incident performance across five categories: speed, quality, resilience, business impact, and AI.
Organize them like this:
Speed → Quality → Resilience → Business → AI Assistance
| Category | Useful Metrics |
| Speed | MTTD (detection time)MTTA (acknowledgment time)MTTR (recovery or resolution time) |
| Quality | Diagnosis timeEscalation rateResolution rate |
| Resilience | Incident volumeRecurrence rateSLA/SLO impactSeverity distributionRecovery capability |
| Business | Number of customers or employees affectedFailed business transactionsRevenue lost during the incidentEmployee productivity hours lostCustomer satisfaction after recovery |
| AI Assistance | AI-assisted decision qualityAI-assisted investigation timeRecommendation acceptance and override ratesAutomated-action rollback and exception rates |
MTTD, MTTA, and MTTR show where delays happen. A short MTTR may reflect a temporary workaround, with the same underlying failure still generating new incidents. Confirming that IT diagnosed the failure correctly and produced a lasting fix also takes quality and resilience data from the other categories in the table.
Forrester’s Incident Management Has Outgrown Its Playbook recommends measuring diagnosis time separately from resolution time. It also calls for greater attention to recurrence, recovery capability, business impact, and the quality of AI-assisted outcomes.
Incident Management Best Practices
Here are some of the best incident management practices IT teams should follow to manage incidents consistently and reduce their impact:
- Define ownership and decision authority before incidents occur.
- Establish clear severity levels and escalation paths.
- Maintain accurate service ownership and dependency information.
- Keep evidence, decisions, actions, and communications in one incident timeline.
- Train responders, run incident exercises, and test recovery procedures and backup communication channels.
- Match automation permissions to an action’s reversibility and potential blast radius.
- Verify service health before closing an incident.
- Review major and recurring incidents.
- Assign owners and due dates to corrective actions.
- Connect incident outcomes to business priorities.
How Is Modern Incident Management Changing?
Forrester doesn’t argue that traditional incident management is obsolete. Ownership, escalation, recovery, and review still matter. What has changed is the environment in which those practices operate.
Failures Spread Faster
Failures spread faster because automation and cloud dependencies can expand the blast radius. A faulty deployment or configuration can move across connected services within seconds, while diagnosis and recovery may take hours.
Context Matters More
Context matters more because responders must understand topology, recent changes, service dependencies, and business impact. That information helps them trace where the failure began, determine which services are affected, and choose an appropriate recovery action.
AI Requires Governance
AI requires governance because agents can investigate, recommend, or execute actions at machine speed. Permissions, human approval, and audit trails should reflect how difficult an action is to reverse and how many systems or users it could affect.
Read The New Rules of Modern Incident Management for a deeper look at how automation, cloud dependencies, operational context, and AI are changing incident operations.
Traditional vs. Modern Incident Management
Here’s how modern incident management differs from traditional:
| Traditional Assumption | Modern Reality |
| An incident can be contained within one service | A failure may cross services, environments, and providers |
| Humans cause and manage incidents | Automation and AI agents can both cause and address failures |
| Faster resolution means better performance | Context, decision quality, and lasting recovery also matter |
| Response tools remain available | Response tooling may share the production failure surface |
| Closing the incident completes the work | Recurrence and follow-up work continue after recovery |
How Does LogicMonitor Support Incident Management?
LogicMonitor helps IT teams move from reactive incident response toward more resilient, autonomous operations. Its AI-first platform connects visibility from user to code across infrastructure, cloud, Internet performance, applications, and digital experience.
Edwin AI uses this connected context to correlate signals, understand service impact, prioritize what matters, guide next steps, and support governed automation.
Teams can then act with greater speed and control while verifying outcomes and keeping humans involved in higher-risk decisions.
