Fast First Contentful Paint keeps users off blank screens and sets up better Core Web Vitals, SEO, and conversion performance.
FCP tracks how long it takes for the first visible content (text, image, SVG, non‑white canvas) to appear on screen after navigation.
Scores under 1.8 seconds are considered fast; anything over 3 seconds is slow and usually points to deeper performance issues.
The same issues that hurt FCP—render‑blocking JavaScript and CSS, slow TTFB, heavy images—also delay LCP and Time to Interactive.
Teams that optimize FCP with tactics like server‑side rendering, code splitting, and image compression have seen meaningful gains in bounce rate and conversion.
What Is the First Contentful Paint?
First Contentful Paint (FCP) measures the time to first paint of elements on a web page and is sometimes confused with First Paint (FP). The difference between the two is that FP measures the time it takes for the first pixels to load in the browser after a user visits a page, whereas FCP measures the time it takes for content useful to the user, such as text or graphics, to load. The two measures would be very close on a fast, simple website accessed via a fast internet connection, but they would differ for a complex website accessed over a slow network.
(source)
For a more formal definition, First Contentful Paint (FCP) is a browser performance metric that measures the time to render the first content of the Document Object Model (DOM) when a web page loads. These DOM elements include images, text, non-white <canvas> elements, and Scalable Vector Graphics (SVG) files.
When FCP is low, the user will instantly see the content when entering the URL and loading the web page. On the other hand, the browser will take a long time to render the initial content when the FCP is high, which the user will perceive as a slow web page.
How First Contentful Paint Relates to Largest Contentful Paint
FCP and Largest Contentful Paint (LCP) measure how quickly elements load on a web page. LCP measures the time it takes for the largest element (often an image) to enter the viewport before the user scrolls or clicks a button.
In contrast, FCP doesn’t differentiate between element sizes in its measurements and simply measures the time it takes the browser to load the first DOM element, independent of its size, whether it’s text, an image, or an SVG.
How First Contentful Paint Affects SEO
Page speed is an important factor Google considers when ranking websites for SEO: a website will rank highly in search results if it loads quickly. FCP is useful for the user because it shows how quickly the page provides visual feedback, even though LCP may be more correlated with the user’s perception of the page speed. For example, the following image shows the difference between FCP and LCP in loading a LinkedIn page.
Although FCP is not a core web vital metric, LCP is a core web vital that can be affected by slower FCP. For example, render-blocking resources like JavaScript and CSS delay FCP, consequently delaying LCP. Furthermore, the page will take more time to reach FCP and, consequently, LCP with larger images.
The Business Impact of First Contentful Paint: A Case Study
Renault Group is a multinational automobile manufacturer in France with branches in over 130 countries. A Google case study claims that Renault Group improved its website bounce rate and conversion rate by optimizing LCP. In its efforts to improve LCP, it used server-side rendering to improve FCP.
First, Renault used Google Analytics to send all the web vitals metrics from actual users of its single-page application (SPA). The results showed a strong correlation between LCP and bounce and conversion rates.
Source web.dev
As LCP increased, the bounce rate also increased, while the conversion rate decreased. Renault Group identified the need to get LCP under 1 second to improve bounce and conversion rates through this analysis.
Renault’s teams set up monitoring with Google Lighthouse and Chrome UX Report API to track progress toward their LCP target. They optimized the single-page application with code splitting, lazy loading, responsive images, and server-side rendering to improve FCP. These changes boosted the share of visitors experiencing fast LCP (under 2.5 s) by 22 percentage points—from 51% to 73% across Renault’s top five domains. (Source web.dev)
What is a Good FCP score?
A good FCP score is generally under 1.8 seconds. The table below shows how the FCP value affects a web page’s performance according to Google Lighthouse.
| FCP (seconds) | Interpretation |
| 0-1.8 | Fast |
| 1.8-3 | Moderate |
| Over 3 | Slow |
How to Measure First Contentful Paint
In the following example, we will see how to measure FCP using WebPageTest. You can go through the following steps to run a test on your chosen web page and retrieve core web vitals information:
- Go to https://webpagetest.org/
- Select the web vitals tab from the main page.
- Enter the web page URL you want to test; we used yahoo.com.
- Select the test configuration you want. If you want to test a mobile rendering, select Mobile-4G, otherwise use Desktop-cable.
- Start the test and wait a couple of minutes to get the final results. The WebPageTest will execute three runs of the page load.
- Go to the performance test results page and click on the Web Vitals section.
- Select View as Filmstrip under Largest Contentful Paints to see the page load frame by frame in 0.5 s intervals, or watch the video to see how the user experiences the page load.
The following is the film strip view for yahoo.com:
You can find the performance results in the Summary tab. In our example, the FCP is 0.603 s for the third run, which is a very good score. The LCP is 1.361 s, indicating that this page has a good load speed.
Additionally, you can compare the metrics for all three runs by clicking on the Compare all runs button on the filmstrip view page. Then, if you scroll down the page, you can see the timing comparison for all the performance metrics. The image below shows the timing comparisons of our example. According to the graph below, our example web page maintained FCP under 1 second for all three runs.
What Contributes to Having a Poor First Contentful Paint?
Render-Blocking Resources
JavaScript, CSS, and HTML are render-blocking resources that take a long time to load and significantly hinder the full page from rendering. They delay the time to reach FCP, affecting LCP and Time to Interactive (TTI). These blocking resources are often non-critical files that you can load after the browser renders the essential resources. It is important to identify the most critical resources and defer the non-critical ones.
For example, the following screenshot shows the page’s performance metrics for https://www.newsfirst.lk/. The FCP is 2.958 seconds, which is very high, and the other core web vitals, such as LCP, CLS, and TBT, are also high.
WebPageTest can identify such render-blocking resources, highlighting them using an orange cross mark. The screenshot above shows the render-blocking resources for our example page, indicating that it includes several render-blocking JS and CSS files.
How to Fix the Problem
The main solution is to defer non-critical JS and CSS until after you have loaded the most critical resources required at the start. Profile your page and identify the blocking elements. Removing non-critical third-party JavaScript and CSS, and minifying scripts, can also help mitigate this issue.
Slow Server Response Times
When the browser makes a network request, it sends the request to the server, which responds with the page content. Server response time is the time it takes the server to send a response to the browser. In terms of website performance metrics, server response time is the Time to First Byte (TTFB), the time it takes the browser to receive the first byte of the page.
A high TTFB indicates that your server response time is higher, directly affecting the time to achieve FCP.
There are several solutions to mitigate this problem:
- Enable content caching for frequently used content like text and images. Caching enables the browser to retrieve content from the cache without loading it from the server every time.
- Use a CDN to deliver static resources like images and videos to reduce the network latency since CDN servers are closer to the client devices.
- Sometimes the server backend logic may be complicated; it may be doing heavy processing before sending a response. In such cases, you can optimize server queries and the backend logic to improve response time.
- Improve the performance of your servers by adding more capacity or more servers.
Unused CSS
Web developers usually use external stylesheets and link them to the main HTML page using a <link> tag. While that is convenient for them, it can affect the FCP if they load unused CSS. The browser parses and processes all CSS files, and it won’t render anything until it finishes processing the CSS, since it is required for page styling. These external CSS files must be downloaded from the network, which may be affected by network delays. Unused CSS also slows down render tree construction, as the browser checks all CSS to build it.
You can find unused CSS by using the PageSpeed Insights tool. The following image shows the unused CSS in our example web page and the potential savings (0.3 s) achievable by optimizing it.
First, identify the most critical CSS using Chrome Dev Tools, declare this CSS inline, and use the “preload” link to load the rest of the CSS asynchronously. Then the browser does not have to wait until it gets downloaded; it will immediately apply the critical CSS required to render the page.
Large Website Images
Image files are among the largest elements of any website and must be downloaded by the browser before they can be displayed. The larger the image size, the longer it takes to load, directly affecting FCP. Poor FCP often happens when large images are not compressed to reduce their size.
WebPageTest shows the content breakdown by MIME type, indicating the size of uncompressed images. For example, according to the image below, there are many image bytes in our example test page, all of which are uncompressed.
It also shows how many bytes you can save by compressing images, as shown below.
Compress images to reduce file size without changing dimensions—modern formats like WebP and AVIF offer better compression than PNG or unoptimized JPEGs. Even JPEG images can benefit from recompression at slightly lower quality settings that remain visually identical.
Use an image CDN to serve optimized, device-appropriate versions automatically. Image CDNs resize, compress, and convert images to efficient formats in real time based on the requesting device and browser, cutting payload and load times.
Excessive DOM Size
If your page has a large DOM tree, it requires significant computing power to render. Having a large DOM tree means there are many invisible DOM nodes that users cannot see in the initial page load. Moreover, a large DOM tree requires more time to compute its styles, increasing memory usage and, in turn, the FCP value.
PageSpeed Insights indicates whether the web page has a large DOM size. The image below shows how it indicates the page’s DOM size: https://www.bbc.com/news/world.
- Use pagination when there are repeated elements, such as lists of products, posts, or comments.
- Using lazy loading to load HTML elements.
- Split the webpage into multiple small pages.
Summing Up
FCP is an essential website performance metric that indicates the time it takes for a web page to render the first content of the DOM. Although not a core web vital, it directly affects the core web vitals like LCP, which determines the SEO ranking of a web page. Several factors contribute to having poor FCP, such as render-blocking resources, unused CSS, uncompressed images, and slow server response time. Web developers can improve FCP and other core web vitals by following the solutions discussed in this article.
Turn blank screens into fast first impressions
Poor FCP costs you users before they see a single pixel of content. LogicMonitor’s synthetic monitoring and real user metrics pinpoint exactly what’s blocking fast paint, so you can ship experiences that load in under 1.8 seconds and keep visitors engaged.
Should I prioritize fixing FCP or LCP first?
Focus on LCP as it’s a Core Web Vital that directly affects SEO rankings, and most fixes that improve LCP (like optimizing render-blocking resources, compressing images, and reducing TTFB) will also improve FCP. Since FCP measures first paint and LCP measures largest paint, addressing the root causes helps both metrics simultaneously.
Will improving FCP actually improve my conversion rate?
Yes. The Renault case study showed that improving LCP (which FCP feeds into) from 51% to 73% of users experiencing fast loads correlated with better conversion and lower bounce rates. Fast FCP keeps users from seeing blank screens, reducing the chance they abandon before your page even appears.
How often should I measure FCP, and should I use lab data or field data?
Use both. Lab tools like WebPageTest and Lighthouse give you controlled, repeatable diagnostics to identify issues. Field data from Chrome UX Report and Real User Monitoring shows how actual users experience your site across different devices, networks, and geographies. Measure continuously and set alerts for regression.
If my FCP is already under 1.8 seconds, should I still optimize it further?
Only if other metrics lag or if you’re aiming for top-quartile performance. Once FCP is fast, shift focus to LCP, INP, and CLS—the Core Web Vitals that directly impact rankings and user experience. Chasing sub-second FCP offers diminishing returns compared to fixing slower downstream metrics.
