SaaS monitoring fails when you only watch what you own.
SaaS performance depends on DNS, BGP, CDN, ISP, and application layers working together. Monitoring just the app misses the full picture.
Intelligent agents deployed close to users reveal last-mile, ISP, and CDN issues that centralized tools can’t see.
Balancing synthetic monitoring with real user monitoring (RUM) provides proactive detection and ground-truth validation in a single workflow.
Monitor from your users’ perspective across the entire internet path to catch problems before they impact productivity.
SaaS is a cloud-based model for delivering software applications over the network rather than requiring users to install and maintain them locally on their computers. As SaaS adoption grows across enterprise IT, it introduces monitoring challenges that traditional tools weren’t built to handle. Traditional monitoring approaches often fall short of comprehensively monitoring SaaS performance due to the distributed, “cloud-first” approach prevalent in most SaaS setups.
When using SaaS, the user experience is shaped by diverse and unpredictable network paths, not just application performance. SaaS applications run on infrastructure outside your control, including ISP paths, CDN edge nodes, and DNS providers, so conventional tools that only watch your own infrastructure can’t identify the root cause of most performance issues.
This guide explores best practices for implementing SaaS monitoring to develop robust network management strategies. We’ll also examine why internet-aware monitoring using intelligent agents extends visibility beyond what conventional monitoring approaches can provide.
Summary of key SaaS monitoring concepts
| Concept | Description |
| Intelligent agents | Use globally deployed agents that monitor performance from real user vantage points, not just the cloud. |
| Full internet stack visibility | End-to-end monitoring across DNS, BGP, CDN, ISP, and application layers to find root causes of specific behaviors. |
| Using the stack map | A visual tool that correlates SaaS performance across internet stack components in real time. |
| Synthetic monitoring in SaaS | Simulated transactions can proactively test the performance and availability of SaaS environments. |
| Real User Monitoring (RUM) | Captures data from real SaaS users to measure actual experience and performance. |
| SLA and alert management | Monitoring of SaaS-specific SLAs and smart alerting to detect and act on anomalies quickly and with precision. |
Best practices and technologies
SaaS monitoring requires a specialized approach to give you accurate visibility into how your network performs.
Intelligent agents
Intelligent agents are a foundational component of any monitoring system designed to cover distributed environments like SaaS. Strategically placed across geographical locations and network vantage points, they examine the end-user experience in real time.
These agents monitor beyond cloud regions, covering last-mile infrastructure, ISP paths, and CDN access points. They reveal SaaS performance degradation with greater accuracy and clarity than internal monitoring tools alone.
Full Internet Stack visibility
Visibility across every component that affects SaaS performance is required for effective monitoring. Beyond the application itself, SaaS performance relies on a set of network protocols and mechanisms that make up the Internet Stack: DNS lookups, BGP propagation, CDN caching and delivery, ISP and transit paths, and endpoint and device quality.
Any SaaS monitoring infrastructure must provide full visibility across all these layers, since SaaS depends directly on them.
Using Internet Stack Map
Achieving full visibility across the Internet stack for SaaS applications requires the right tools. LM Internet Stack Map, powered by Cacthpoint, provides this kind of full-stack visibility.
Internet Stack Map correlates and displays performance data across all layers of the internet stack, from DNS to BGP, from CDN to ISP, and application layers, all in real time. It helps teams identify which layer is responsible for a slowdown, including issues that span multiple providers.
In SaaS deployments, numerous issues may arise beyond the application itself. Tools like Internet Stack Map enable IT teams to view all layers together, clearly indicating interdependencies and making it much easier to pinpoint the true origin of service degradation or outages, especially in multi-region, multi-provider SaaS environments.
SaaS synthetic monitoring
Synthetic monitoring simulates user interactions, network operations, and traffic patterns from various locations at regular intervals. It monitors network and application behavior even without real user traffic.
Synthetic monitoring involves executing automated scripts that mimic typical user behavior. For SaaS applications, this can include running a particular application and performing specific tasks. This helps teams catch issues before they affect users, in a controlled environment. With appropriate design, synthetic monitoring can closely approximate real traffic, taking into account both geographic diversity and useful benchmarking and SLA validation.
Real user monitoring (RUM)
Unlike synthetic monitoring, real user monitoring (RUM) observes how real users experience SaaS applications and how network traffic patterns emerge from that usage. RUM captures metrics from actual browsers and end devices. Teams typically deploy RUM via intelligent agents on end devices.
RUM complements synthetic monitoring by filling gaps in understanding the full range of network and SaaS application behavior under various conditions. RUM is especially critical for mobile-heavy SaaS deployments and for identifying variability in real-world performance, aspects that can’t be fully observed with a synthetic monitoring approach.
Effective SaaS monitoring depends on how well an organization responds to specific events. While monitoring provides visibility into performance and availability, it’s the speed and precision of the response that determines whether an SLA is met.
SLAs serve as benchmarks for acceptable performance, helping to ensure that the user experience remains consistently high, even during unexpected disruptions or degradations.
To support SLAs, teams must design automated responses alongside intelligent alerting mechanisms that notify the appropriate team members. These systems should respond swiftly to incidents and prioritize them by severity and impact. Employing smart alerting techniques that can distinguish genuine issues from noise enables teams to detect anomalies promptly and take precise, effective action.
Recommendations and implementation tips
Deploy intelligent agents as close as possible to users. Intelligent agents should be strategically positioned, both geographically and logically, close to end-users. By doing so, you can gain accurate visibility and detect localized issues that would otherwise be invisible from a more centralized viewpoint.
Use the Stack Map for more effective troubleshooting. Viewing the full Internet Stack Map helps pinpoint performance bottlenecks and precisely identify where failures or slowdowns are occurring. Issues arising from complex interrelationships among various Internet Layers can be observed more clearly.
Balance RUM and synthetic monitoring. By drawing on telemetry from both, you get a more complete picture of SaaS behavior.
Configure SLAs and alerts within the optimal threshold. Strike a balance to ensure rapid responses to genuine issues while avoiding excessive or unnecessary notifications that can contribute to alert fatigue.
Use SaaS monitoring for validating the delivery of SaaS services via SLAs. Use SaaS monitoring data to hold vendors accountable to their promised service levels.
Connect SaaS monitoring data with DevOps and incident workflows. Feeding real-time performance data and incident insights back into development and operations teams helps surface recurring issues in development sprints, fine-tune application behavior, and improve deployment practices.
Last thoughts
According to Backlinko’s 2025 SaaS report, companies now use an average of 112 SaaS applications, up from 80 in 2020. More SaaS applications mean more layers of internet infrastructure beyond your control, making root cause isolation harder without full-stack visibility.
Start with intelligent agents at the edge, full visibility into the internet stack, and a balanced synthetic-plus-RUM approach to stay ahead of issues before they reach your users.
See exactly where your employees’ digital experience breaks down, from endpoint to application.
Bring endpoint, network, and SaaS performance into a single view so IT can move from ‘it looks fine here’ to clear answers about what employees are actually experiencing.
What’s the difference between synthetic monitoring and real user monitoring for SaaS?
Synthetic monitoring runs automated scripts that simulate user interactions from multiple locations, testing performance proactively even without real traffic. Real user monitoring (RUM) captures data from actual user sessions, showing how people experience the application in practice. Synthetic gives you controlled baselines; RUM gives you ground truth. Using both together covers proactive detection and real-world validation.
Why do traditional monitoring tools fall short for SaaS applications?
Traditional tools focus on infrastructure you own and operate. SaaS applications depend on infrastructure you don’t control, including ISP paths, CDN edge nodes, DNS providers, and cloud regions. Without visibility into these layers, you can’t diagnose the root cause of performance issues that originate outside your network.
How do you identify where SaaS performance problems are happening?
SaaS performance issues often originate outside the infrastructure you control, including DNS, CDN, ISP, cloud, or last-mile network layers, so effective monitoring needs visibility across the full delivery path rather than the application alone. Correlating data from multiple layers helps teams isolate whether the problem is with the app itself or somewhere along the route users take to reach it.
How should intelligent agents be deployed for SaaS monitoring?
The most effective SaaS monitoring solutions rely on a globally distributed network of intelligent agents that run from the same vantage points as real users, rather than only from cloud data centers. By using a provider that operates agents across last‑mile networks, ISP paths, and CDN access points, IT teams gain visibility into issues that would never appear if monitoring ran solely from centralized cloud regions.
