VPN monitoring can’t stop at the tunnel. It needs to cover the full path from user to application.
VPNs add encryption, encapsulation, and latency overhead that directly impacts user experience, making continuous performance monitoring a requirement for any production deployment.
Internet path analysis, synthetic testing, and endpoint monitoring work together to detect issues before they reach actual users.
Security monitoring and SLA compliance tracking must operate in tandem, because stronger encryption often comes at the cost of higher latency.
Build VPN monitoring into your broader observability strategy now, with SASE-ready architecture in mind, so you don’t have to rearchitect when the transition comes.
VPN Monitoring
From enabling remote access to corporate networks to securing site-to-site connections, virtual private networks (VPNs) have become increasingly essential in today’s security-conscious networking industry.
As their usage grows, so does the need for greater observability and visualization of VPN performance. Real-time monitoring of performance, security, and compliance has become a core part of VPN operations.
This guide explores best practices for VPN monitoring to ensure optimal end-to-end performance, security, and reliability in modern network environments.
Summary of key VPN monitoring concepts
The following table lists concepts and best practices for VPN monitoring that will be examined further in this article.
| Concept | Description |
| Real-time performance monitoring | Continuously track VPN latency, throughput, and packet loss. |
| Endpoint and network monitoring | Monitor both ends of the VPN tunnel, including remote devices and data centers. |
| Internet path analysis | Evaluate public Internet segments affecting VPN performance, including BGP performance and path selection. |
| Synthetic testing | Synthetic monitoring is used to emulate real user behavior over the VPN. |
| Security monitoring | Detect and alert for unusual traffic patterns, breaches, or attacks. |
| SLA compliance tracking | Ensure VPN service providers meet agreed performance standards. |
| Integration with other monitoring tools | Link VPN monitoring to broader observability and diagnostic platforms. |
| Prepare for the evolution from VPN to SASE monitoring | Future-proof VPN monitoring designs by taking into account industry trends toward SASE. |
Understanding VPNs
A VPN is a technology for securely transmitting data over any network by encapsulating it within additional headers. The headers are added to establish secure tunnels between two endpoints. Tunneling refers to encapsulating packets within other packets before transmitting them over a public or untrusted network, such as the Internet. Encryption ensures that even if data is intercepted, it remains unreadable without proper decryption credentials. The VPN ensures that only authorized and authenticated parties can access and interpret the transmitted information.
Types of VPNs
VPNs can be categorized by purpose, architecture, and deployment method.
- Remote access VPN enables individual users to securely connect to a private corporate or enterprise network over the Internet from a single end device, such as a PC or mobile phone.
- Site-to-site VPN is used to interconnect remote networks to each other, typically a branch office network to the headquarters.
- Cloud VPN securely connects on-premises network infrastructure to cloud environments.
Operations
The following diagram shows one particular use case: a PC running a VPN client connects to a VPN server over an untrusted network.
Initially, the VPN client establishes a tunnel between itself and the VPN server. Initial communication between the client and server authenticates the client. The server and client agree upon the methods they’ll use for encapsulation and encryption. Once a successful agreement is reached, the tunnel is considered established.
When the VPN client sends traffic to the server, it takes the original IP packet and encapsulates it as the VPN tunnel payload. A VPN header is prepended to the original IP packet, and a new IP header is added containing the destination IP address of the VPN server. The VPN header includes the necessary information to encrypt the original IP packet on egress from the VPN client and decrypt it on ingress to the VPN server based on the initial agreement between the two entities.
The original IP packet is encrypted, encapsulated, and forwarded to the VPN server using the new outer IP header. During transport over the untrusted network, the payload remains confidential. Once it reaches the VPN server, it’s decapsulated, decrypted, and sent to its final intended destination based on the original IP header.
VPN protocols and encryption methods
A wide variety of protocols are used to tunnel and encrypt data using VPNs. The methodologies must be agreed upon between the entities acting as VPN endpoints. The methods vary significantly in security level, degree of overhead, complexity, and availability.
VPN protocols:
- IPsec (Internet Protocol Security)
- SSL/TLS VPN (Secure Sockets Layer / Transport Layer Security)
- OpenVPN
- WireGuard
- L2TP/IPsec (Layer 2 Tunneling Protocol with IPsec)
- PPTP (Point-to-Point Tunneling Protocol)
- IKEv2/IPsec (Internet Key Exchange v2)
- SoftEther VPN
- SSTP (Secure Socket Tunneling Protocol)
- MPLS VPN
Encryption methods:
- AES (Advanced Encryption Standard): AES-128, AES-192, AES-256
- ChaCha20
- Blowfish
- 3DES (Triple Data Encryption Standard)
- Camellia
- RSA (Rivest-Shamir-Adleman)
- ECC (Elliptic Curve Cryptography)
- DH (Diffie-Hellman Key Exchange)
- ECDH (Elliptic Curve Diffie-Hellman)
- SHA (Secure Hash Algorithm): SHA-1, SHA-256, SHA-512
Limitations
The primary disadvantage of VPNs is that they introduce overhead that can affect network performance and resource utilization.
Encryption overhead
VPN encryption algorithms require additional processing power. The stronger the encryption algorithm, the more CPU resources are consumed, potentially reducing the performance of network devices.
Encapsulation overhead
VPN protocols encapsulate packets with additional headers, which increase the total packet size. This leads to higher bandwidth consumption and potential fragmentation, especially if the packet size exceeds the underlying network infrastructure’s Maximum Transmission Unit (MTU).
Latency overhead
The steps involved in encapsulating, encrypting, decrypting, and decapsulating data introduce delays, which increase latency.
Management overhead
VPNs add complexity to any network, resulting in management, administration, and maintenance overhead.
VPN monitoring fundamentals
The benefits that VPNs deliver, combined with their limitations and complexities, make VPN monitoring even more important.
Real-time VPN performance monitoring
Monitoring VPN performance metrics like latency, throughput, and packet loss helps network administrators quickly detect and respond to performance degradation. Proactive monitoring helps identify issues such as congestion or jitter that impact VPN reliability and the user experience.
Effective VPN management must extend beyond the tunnel itself, as it requires visibility into both ends of the VPN. Monitoring remote endpoints, VPN gateways, and the data center and cloud infrastructure used by VPNs is necessary to ensure end-to-end security and performance. In this way, compliance can be maintained and VPN operations optimized, especially for mission-critical applications.
Internet path analysis is a method for monitoring and evaluating public Internet segments that can impact VPN performance. Since VPNs primarily depend on the Internet for transport, various factors, including BGP routing, network congestion, and suboptimal path selection, affect their effectiveness, including latency and reliability. Route changes, traffic blackholing, and ISP-level disruptions that can potentially degrade VPN connectivity can be detected and mitigated.
LogicMonitor Digital Experience extends visibility into these public network paths through internet performance monitoring, delivering the deep visibility that VPN operations require. By identifying troublesome segments and optimizing route selection, teams can maintain a stable and high-performing VPN experience for their users.
Synthetic testing and VPNs
Compared to passive monitoring, which relies on real traffic, synthetic testing generates controlled test traffic to evaluate specific metrics. It simulates real user interactions to assess performance, availability, and reliability, providing greater control and enabling earlier issue detection before they affect actual users.
Synthetic testing helps identify issues across various locations and endpoints when used with VPNs. It can also be an important part of an organization’s strategy for validating VPN SLAs.
Security and SLA compliance
VPNs are prime targets for threats such as man-in-the-middle attacks, unauthorized access, and traffic hijacking, making continuous surveillance essential. VPN SLA compliance requires tracking key performance indicators, including uptime, latency, packet loss, and throughput, to ensure providers meet agreed-upon standards. This is especially true for mission-critical services such as site-to-site and cloud VPNs.
However, increasing the security level has a trade-off in VPN performance. The more secure encryption methods typically have a greater impact on latency and performance. Security monitoring must be coupled appropriately with SLA compliance monitoring to ensure that both performance and security requirements are met.
Pairing security evaluation with performance analytics gives teams a more complete picture of VPN health, covering both threat exposure and service reliability.
VPN monitoring should be integrated into an organization’s broader monitoring, visualization, and observability strategy. It should be integrated with network performance monitoring (NPM), security information and event management (SIEM) systems, and application performance monitoring (APM) platforms. This integrated approach ensures that VPN metrics aren’t collected and analyzed in isolation but are used as part of the broader network and security stack.
A growing number of organizations are adopting secure access service edge (SASE) architectures and augmenting or replacing VPNs with zero-trust and cloud-based security models. As more enterprises move toward SASE, VPN monitoring strategies will need to evolve to accommodate identity-driven security models and cloud-based visibility.
SASE integrates zero-trust principles, cloud-based security, and software-defined networking. These aspects must be considered when deploying VPN monitoring today to ensure that current monitoring strategies are well aligned with SASE frameworks for future transitions. Many teams are moving toward converged visibility across on-premises, hybrid, and cloud environments. Planning for that shift now can reduce the cost of transition later.
Last thoughts
For organizations running VPN infrastructure, monitoring is a core part of a complete network strategy. Network performance, security, and reliability are key elements of a successfully deployed and operational network. By continuously gaining visibility into latency, throughput, security threats, and compliance metrics, organizations can ensure secure, high-performance connectivity for their users.
As enterprises transition their networks to SASE and zero-trust security models, unified platforms that combine infrastructure monitoring with Internet and experience visibility become essential.
See How LogicMonitor Unifies VPN, Network, and Internet Monitoring.
LogicMonitor Digital Experience extends infrastructure observability with Internet path analysis and synthetic testing in a single view, so your team can catch more VPN issues earlier.
What metrics should I monitor for VPN performance?
Focus on latency, throughput, packet loss, and jitter. These metrics directly impact user experience and help identify congestion, misconfiguration, or capacity issues before they escalate.
How does Internet path analysis improve VPN reliability?
VPNs rely on the public Internet for transport. Internet path analysis monitors BGP routing, ISP-level disruptions, and suboptimal path selection so teams can detect and respond to issues outside their direct control.
What’s the difference between passive VPN monitoring and synthetic testing?
Passive monitoring analyzes real user traffic to identify issues after they occur. Synthetic testing generates controlled test traffic to proactively evaluate performance, availability, and SLA compliance before real users are affected.
How should I prepare my VPN monitoring strategy for SASE?
Build VPN monitoring into your broader observability strategy today, with SASE-ready architecture in mind. That means adopting platforms that support identity-driven security models, cloud-based monitoring, and converged visibility across on-premises, hybrid, and cloud environments.
