GUIDE TO SYNTHETIC MONITORING
Synthetic Testing: Key Benefits, Metrics & Best Practices
Learn about the benefits and key metrics of synthetic testing, which simulates traffic and user actions to assess web application performance and identify issues.
9–13 minutes
June 23, 2026
Denton Chikura
IN THIS DEEP DIVE
CHAPTERS
    Synthetic testing turns your CI/CD test scripts into production monitors. The same checks that validate a release can run continuously to catch regressions.
    • Synthetic testing simulates user traffic under controlled conditions to measure availability, speed, workflow reliability, and network performance.
    • Five metric categories matter: global availability (uptime, error rates), application speed (TTFB, LCP), workflow success rates, network/CDN performance, and end-user experience (FCP, CLS).
    • Synthetic testing and RUM cover different ground. Synthetic catches problems proactively under controlled conditions, RUM captures real-world variability and user-specific issues.
    • Build your synthetic tests in CI/CD, then shift them right into production monitoring. One test suite, two purposes, zero coverage gaps.
    Synthetic Testing
    Synthetic testing uses artificially generated traffic to simulate expected traffic patterns and evaluate network performance and behavior. The primary goal is to identify any issues in the service before real clients encounter them. It can also be used to test changes before releases and for load testing.
    Real User Monitoring (RUM) captures performance data from actual visitors in varying conditions. However, synthetic testing uses predefined scripts to simulate user actions such as loading a home page, navigating to a product page, or calling an API from specific test nodes around the world.
    Synthetic testing allows organizations to assess the availability, functionality, and performance of a web or SaaS application from the client’s perspective. It improves the overall observability of the application and allows for the identification of cause-and-effect relationships.
    This article highlights and explains the key benefits of using synthetic testing.
    Summary of key synthetic testing metrics
    GoalKey metricsBenefit
    Global service availabilityService uptime %Error rate analysisGlobal reachabilityChecks that your application is available for users in all target regions, preventing downtime and regional outages.
    Application speed and responsivenessPage load durationTime to First Byte (TTFB)Time to Last Byte (TTLB)API response timeNetwork latencyReduces load times and server delays, enhancing user experience and search ranking.
    Smooth user workflowsTransaction success rateWorkflow completion timeThird-party dependency checksValidates that critical transactions and processes work reliably from start to finish.
    Network and third-party service performance optimizationDNS resolution speedCDN performanceHop-by-hop latency breakdownIdentifies and resolves bottlenecks in DNS, CDN, and network paths to improve delivery speed and reliability.
    End user experience assessmentFirst Contentful Paint (FCP)Largest Contentful Paint (LCP)Cumulative Layout Shift (CLS)Render start timeSimulates varied devices, browsers, and network conditions to ensure consistent performance for all users.
    The primary purpose of monitoring global service availability is to ensure that your application is reachable and operational for all intended users worldwide. You can ensure that your web or SaaS application is accessible and functional for users, regardless of their location. Synthetic tests are executed from test nodes in your target regions at regular intervals (e.g., every 5 minutes) to help you detect performance degradations even during low-traffic periods when RUM data might be sparse.
    As shown in the image below, the wider the network of locations, the clearer a picture of accessibility you will get. Ideally, you want to see a granular breakdown of test result data by geography. It is also important to remember the law of large numbers: the more independent observations you can get, the more accurate your averaging will be if you need to calculate some high-level metrics of your application’s performance.
    Test point coverage map
    You can use various availability metrics as a class of measurements that focus on whether the service responds successfully under test conditions. For example,
    • Service uptime: Monitors the percentage of time the application or website remains operational and accessible without errors
    • Error rate analysis: Measures the proportion of failed requests (e.g., HTTP 4xx or 5xx errors) to ensure consistent functionality
    • Global reachability: Validates the application’s accessibility across multiple geographic regions and networks to guarantee a consistent experience for all users
    Having such metrics allows you to measure your service’s availability to ensure compliance with certain SLAs. Availability level is often defined as the number/proportion of error responses from a service, so you can see and analyze all responses by code, as shown in the image below.
    Amount of responses by codes
    You can also identify potential network issues or performance bottlenecks in your application across different regions. This is a good example of a proactive approach where you can spot some geographic-specific errors (for example, DNS resolution issues) before they start impacting your real users. Another significant benefit is the ability to test your application’s performance in regions where you do not yet operate (do not have clients) but plan to launch.
    Fast application response affects both the user experience and how your web app ranks in search engines. The speed and responsiveness of an application can be measured by the time it takes for various components to respond and render. Synthetic testing runs scripted scenarios under controlled conditions, allowing you to compare results over time without the noise of real-user variability. You can also track trends and promptly notice degradations after any release or infrastructure change.
    Some tests can be run right from your browser. In the following image, you can find out how long it takes for the first few steps to load your app.
    Example of statistics available in the browser
    However, you need a specialized tool to continually monitor and obtain high-quality data for historical views, analysis, visualization, and a holistic view of the network.
    The following performance metrics are essential to understanding not just whether the service works, but how quickly it delivers value to the user.
    • Page load duration: Tracks the total time required for a webpage to fully load, including all associated resources like CSS, JavaScript, and media files.
    • Server response time (TTFB/TTLB): Measures the time taken by the server to respond with the first byte (for TTFB) or last byte (for TTLB) of data after a request is made.
    • API response time: Monitors API responsiveness, including single API calls and multi-step transactions, to ensure backend systems operate efficiently.
    • Network latency: Assesses the delay in data transmission between the server and client, highlighting potential bottlenecks.
    Example benchmarks that you should aim for:
    Metric/StateGoodNeeds improvementPoor
    TTFB< 800 ms800 – 1800 ms> 1800 ms
    FCP< 1.8 sec1.8 – 3.0 sec> 3.0 sec
    LCP< 2.5 sec2.5 – 4.0 sec> 4.0 sec
    A good practice is to set up alerts when a metric exceeds its thresholds and respond promptly.
    User journeys and workflows
    Workflows rely on many complex, multi-step processes, such as login, checkout, and form submission, to operate reliably from start to finish. With synthetic testing, you can monitor whether every step of a process, as well as the dependencies between them, operates as intended from start to finish. Both the success rate and efficiency of end-to-end user workflows can be simulated and monitored for accurate functionality.
    Monitor and analyze the execution time of both individual scenarios, step by step, and of scenarios compared with one another, as shown in the figure below.
    Execution time for key scenarios
    You should create scenarios that cover both long, end-to-end workflows and shorter, isolated ones. For example, tests can be set up for general scenarios of user behavior, such as logging in or performing a final target action, and for isolated tasks, such as searching for information. That way, you can improve your app’s observability and identify problem areas with greater accuracy.
    Transactional metrics appropriate for workflow testing include:
    • Transaction success rate: Measures the percentage of successful critical workflows (e.g., login, checkout, or form submission).
    • Workflow completion time: Tracks how long it takes to complete a full user journey or transaction.
    • Third-party dependency checks: Monitors the performance of external services (e.g., payment gateways, analytics) that are essential to smooth operation.
    Any significant deviation in the graph (as shown in the picture below) may indicate problems.
    Login script success rate metric
    Slow or unreliable network components should be measured, as they can affect the user experience. CDN is designed to accelerate content retrieval, especially media, and to speed up actions like video buffering and file downloads. If you use this technology in your application, you should properly monitor its functionality.
    Synthetic testing measures these layers directly, so you can tell whether an issue is within your system or elsewhere. Tests can be targeted instead of scheduled. If you suspect a problem in a specific region or with a particular vendor, you can run synthetic tests from specific locations or against specific endpoints to confirm it. This, to some extent, echoes what we previously attributed to the item “Third-party dependency checks” (especially regarding the CDN). Still, it is customary to consider and analyze it separately.
    Some metrics to measure include:
    • DNS resolution speed: Measures the time taken to resolve a domain name into an IP address, ensuring efficient domain name resolution. This directly affects the page loading speed, influencing user satisfaction.
    • CDN performance analysis: Evaluates the effectiveness of content delivery networks in delivering assets quickly and reliably from multiple geographic locations.
    • Hop-by-hop latency breakdown: Provides latency metrics for each network hop, enabling precise identification of bottlenecks along the data path. This helps identify problems between specific cloud regions and/or SaaS APIs.
    End-user experience assessment
    Synthetic testing focuses on the user experience and allows you to extract more valuable observations, unlike traditional network monitoring, where you see infrastructure metrics but are unaware of how they relate to the user experience.
    Replicating real-world conditions is a good practice for assessing whether your application performs consistently across different devices, browsers, and networks. There are various environmental simulation metrics that can help you test the same workflow under varied operating conditions. The idea is to help replicate user interactions and assess how real users would experience the application under various conditions.
    Metrics include:
    • Initial content visibility (FCP): Measures the time required for the first visible content (e.g., text or image) to appear on the screen.
    • Key element rendering (LCP): Measures the time to render the largest visible element on the page, which is critical to user perception of performance.
    • Cumulative Layout Shift (CLS): Measures the instability of content by adding up the displacement (of all elements) that occurs independently of user actions.
    • Page rendering metrics (Render start): Tracks the time until the page begins rendering visible content, providing insights into perceived performance.
    Such measurements provide valuable insights and ideas for improvement.
    In operational practice, you should maintain a test matrix of device-browser-network combinations that reflect your actual user base. For example, if 40% of your traffic comes from older Android phones on 4G networks, those conditions should be routinely simulated. Comparing render start times across conditions can further reveal how device performance and network bandwidth affect perceived speed.
    Synthetic testing vs RUM: Excluded metrics
    Real user monitoring is a passive monitoring that collects user behavior data, such as page load time, response speed, errors, and other metrics, directly from users’ browsers or apps. RUM typically uses a lightweight JavaScript embedded in the code of a website or application. This code collects performance and user interaction data and sends it to a monitoring system.
    Environment coverage by Synthetic testing and RUM
    Synthetic testing and RUM complement each other well. Synthetic testing is typically aimed at preventing user issues and can test multiple environments simultaneously.
    If any issues arise with real users, RUM helps analyze and better understand them, surface errors, and provide additional metrics. For example, First Input Delay (FID) requires actual user interactions and cannot be measured via synthetic testing. Additionally, metrics such as packet loss and IoT-specific protocols (e.g., MQTT) are only relevant in specialized use cases and are typically within the scope of RUM.
    Testing to monitoring: The shift-right journey
    Synthetic testing begins early in development with automated scripts that validate functionality and performance. These tests, typically built with modern frameworks (such as Playwright), are integrated into the CI/CD pipeline to verify changes before deployment. The same suite serves multiple purposes, such as validating features in staging, conducting stress testing, and transitioning to production monitoring checks.
    Different implementations are possible. It is recommended to additionally configure the development environment so that new features are not deployed to production without test scenarios. This way, you can see any metrics degradation in the test and stage environment before the new version is released to production. Depending on the metrics’ values, you can then decide whether to roll out the new version.
    Also, the implemented test scenarios can be easily reused and deployed across different environments thanks to CI/CD pipelines.
    For modern Monitoring or Infrastructure as Code initiatives, your chosen synthetic testing tool must offer the foundational components, such as a comprehensive API or a specific Terraform provider.
    Conclusion
    Synthetic testing is a powerful approach that significantly benefits your app by improving performance and maximizing the user experience. It allows for a significant increase in observability, uptime, and reliability. The more granular the measurements you can see, the better you can understand what exactly needs to be improved in your application.
    Start synthetic testing across your entire delivery chain.
    Run synthetic tests from hundreds of global vantage points, covering availability, performance, workflows, and network paths with one unified platform.
    Request a demo
    What is synthetic testing and how does it work?
    Synthetic testing uses artificially generated traffic to simulate user actions — like loading pages, navigating workflows, or calling APIs — from test nodes distributed around the world. It runs predefined scripts at regular intervals to proactively identify availability, performance, and functionality issues before real users encounter them.
    How does synthetic testing differ from real user monitoring (RUM)?
    Synthetic testing uses scripted simulations under controlled conditions to proactively detect issues, while RUM passively collects data from actual user sessions. Synthetic testing excels at consistent benchmarking, pre-launch validation, and testing in regions without existing traffic. RUM captures real-world variability and metrics like First Input Delay that require actual user interaction.
    What are the most important synthetic testing metrics to track?
    Key metrics span five categories: global availability (uptime, error rates, reachability), application speed (TTFB, TTLB, page load duration), workflow reliability (transaction success rate, completion time), network performance (DNS resolution, CDN performance, hop-by-hop latency), and end-user experience (FCP, LCP, CLS, render start time).
    How can synthetic testing be integrated into CI/CD pipelines?
    Test scripts built for QA and staging validation can shift right into production monitoring. The same Playwright or Selenium scripts that verify functionality before deployment can run continuously in production to detect regressions. Infrastructure-as-code tools like Terraform can manage synthetic monitoring configuration programmatically, making the testing-to-monitoring transition seamless.
    By Denton Chikura
    Technical Writer
