Synthetic website monitoring uses scripted, simulated user interactions to continuously test your website’s performance, even when no real traffic is flowing.
Synthetic monitoring runs scripted tests that simulate user journeys, such as logging in, browsing, or completing a checkout, so you’re testing what users actually do rather than just checking uptime.
Unlike real user monitoring, synthetic testing is fully controlled. You set the location, device, browser, and frequency. This makes it ideal for consistent SLA tracking and regression testing.
Synthetic tests can alert you to slowdowns or downtime during low-traffic hours, when real user data is sparse and problems are easiest to miss.
For the full picture, combine Synthetics and Real User Monitoring (RUM) with Internet Performance Monitoring, which adds visibility into Internet paths and third-party services. Synthetic testing alone won’t capture every variation real users experience.
The Role of Synthetic Website Monitoring in Your Overall Monitoring Strategy
Your checkout page loads in under two seconds from your office in Austin, but a customer in Mumbai waits nine seconds and abandons the cart. Without synthetic monitoring running from global vantage points, that gap stays invisible until revenue reports surface it weeks later.
Synthetic monitoring simulates real user traffic and behavior on a network to evaluate its ability to support and respond correctly to traffic. Similarly, synthetic website monitoring tests and validates website performance by simulating user interactions. It is achieved through specialized automated scripts that simulate user interactions, such as website views, form submissions, transactions, and other online activities.
Synthetic website monitoring is one capability within LogicMonitor Digital Experience, alongside Real User Monitoring (RUM) and Internet Performance Monitoring (IPM), which adds visibility into Internet paths and third-party services.
RUM observes actual users in real time. In contrast, synthetic monitoring operates in a controlled and predictable environment. It is ideal for catching and resolving problems before real users experience them.
This article explores the implementation of synthetic website monitoring, along with key best practices, practical tips, and common pitfalls to avoid.
Summary of key synthetic website monitoring concepts
| Concept | Description |
| Simulate real user journeys | Go beyond uptime checks by scripting key workflows such as login and checkout, to reflect true user interactions |
| Monitor from diverse locations | Run tests from multiple global endpoints to catch regional performance issues and CDN bottlenecks |
| Define meaningful thresholds | Set realistic expectations for load times and availability, informed by SLAs and experience level objectives (XLOs) |
| Alert smartly and reduce noise | Configure actionable alerts to avoid alert fatigue and ensure fast, appropriate responses |
| Combine with real-user insights | Integrate synthetic monitoring with real user monitoring for complete visibility into performance |
Synthetic website monitoring strategies
To get real value from synthetic monitoring, focus on strategies that mirror how people actually use your site.
While basic uptime evaluates a website’s reachability, it doesn’t paint the whole picture. Real user journeys involve multi-step processes and interactions, such as logging in, adding products to a cart, searching for content, completing checkout, and consuming all types of media. These interactive flows must be tested as a whole to ensure the end-to-end experience works smoothly. Thus, not only will the website’s technical aspects be evaluated, but also the user experience, which is the ultimate metric.
Synthetic website monitoring must take place from a broad set of global locations, including last-mile, broadband, and mobile endpoints. Businesses with a global user base require a worldwide evaluation of website performance. For example, users in Tokyo may experience a website much differently than users in Toronto due to differing routing conditions, CDN edge behavior, or ISP-specific congestion.
LogicMonitor Digital Experience provides visibility from global vantage points, including last-mile and regional endpoints, to help teams assess performance across broadband and mobile networks.
Monitoring systems are only as good as the metrics they measure. Because of the complexities involved in synthetic website monitoring, thresholds should be set with care. Not all response time spikes or brief outages are critical. However, without well-defined thresholds, network administration teams may either overreact to non-issues or underreact to severe degradations.
To define meaningful thresholds, they should be:
- Tied to specific Service Level Agreements (SLAs), such as homepage loading must be under 2 seconds, 95% of the time
- Adapted to take into account user expectations and device and network diversity.
- Content-aware, as different pages with different content may have different performance baselines.
These thresholds must be tuned to appropriate levels to minimize noise while preserving responsiveness. This helps support teams to react swiftly without burning out.
An XLO (experience level objective) framework attempts to achieve this balance. Going beyond simple SLAs to track performance, XLOs aim to align thresholds more closely with business goals rather than technical data that only matters to engineers.
Bridge the gap with RUM
Synthetic website monitoring is an excellent way to observe a website’s behavior under conditions not commonly encountered in normal operations. Because it is highly controlled, even some of the most unusual network and activity load variations and distributions can be reproduced and tested.
Having said that, it is important to note that real user monitoring (RUM) complements synthetic testing by observing how actual users experience the website under varying conditions, providing a more complete website monitoring picture. By combining synthetic website monitoring with RUM, you can:
- Compare expected vs. real performance
- Validate test scripts with production behavior
- Detect anomalies that scripts might miss
LogicMonitor Digital Experience brings synthetic and real user data together to help teams understand website performance and user impact.
Synthetic website monitoring metrics
Detailed metrics captured during each synthetic test provide invaluable insight, pinpointing where delays occur, what elements slow down transactions, and how users may experience a website across multiple browsers, devices, and network locations.
The following are some of the most important performance and reliability metrics for synthetic website monitoring. Every organization must determine which ones matter most based on its requirements.
Core timing metrics
- Page load time – the time it takes for the page to fully load, including resources
- DNS lookup time – the time it takes to resolve a domain name into an IP address
- Time to first byte (TTFB) – the time between the request and the arrival of the first byte of the response
- Start render/First contentful paint (FCP) – the time until the first visible content appears.
- Time to interactive (TTI) – when the page becomes fully usable, not just visible
- Speed index – a calculated score that indicates how quickly page content is populated
Web vitals and user experience metrics
- Largest contentful paint (LCP) measures the load speed of the most significant element.
- Cumulative layout shift (CLS) measures visible stability during load.
- Total blocking time (TBT) measures how long the web page is unresponsive to user input between FCP and TTI.
- Error rate is the percentage of failed steps, such as login failures or JavaScript errors.
- Page weight is the total size of the page and its resources.
Transaction and flow-specific metrics:
- Step duration – time taken for each step in a user’s journey.
- Redirect time – time lost due to redirects.
- Third-party resource impact – contribution of time and load from external content.
These metrics can be observed and analyzed at varying levels of detail, depending on the requirements of the specific website. They provide a much more detailed picture of website performance and should be leveraged accordingly.
Recommendations and best practices
Best practices for the implementation of synthetic website monitoring are given below.
Automate key user flows early
When generating synthetic user activities, start with the most critical user paths, such as login, checkout, and content search, and build out scripts from there.
Match frequency to business impact
Critical services and high-traffic pages should be tested more often, say every minute. In contrast, those with low priority can be tested hourly.
Review thresholds regularly
Because user behavior can change with new products or website design changes, SLAs should be reviewed regularly to refine thresholds.
Prioritize alerts
Using a tagging system and meaningful classification, teams can quickly distinguish between warnings and emergencies, allowing them to respond appropriately to various alerts.
Integrate broadly
Synthetic website monitoring is one capability within LogicMonitor Digital Experience and the broader LogicMonitor platform.
Last thoughts
For businesses that rely heavily on their website for success, synthetic website monitoring is no longer a “nice to have” feature. It supports website reliability within LogicMonitor Digital Experience, helping teams identify performance issues and improve digital experiences for users.
See how LogicMonitor Digital Experience connects user experience to root cause.
Synthetics helps teams identify website issues, while LogicMonitor Digital Experience extends visibility beyond infrastructure to user experience, Internet paths, and third-party dependencies.
How often should synthetic tests run?
Test frequency should match business impact. High-traffic, revenue-critical pages benefit from tests running every minute. Lower-priority pages can be tested hourly. The right cadence depends on the cost of a missed issue and your team’s capacity to act on results.
How does synthetic monitoring differ from real user monitoring?
Synthetic monitoring uses predefined scripts to simulate user behavior in a controlled environment. Real user monitoring collects data from actual users as they interact with your site. Synthetic monitoring is better for proactive testing and SLA tracking; real user monitoring reflects actual end-user experience. Most comprehensive strategies use both.
What can synthetic monitoring detect that real user monitoring misses?
Synthetic monitoring can detect slowdowns and downtime during periods with little or no real user traffic, such as overnight or in underserved geographic regions. It also lets you test specific user journeys consistently over time, making it easier to catch regressions after deployments.
What are common pitfalls when setting up synthetic monitoring?
The most common issues are overly sensitive thresholds that generate alert noise, scripts that break after UI changes because they aren’t maintained alongside releases, and insufficient geographic coverage that misses regional performance problems. Starting with a small set of high-impact flows, tuning thresholds based on real baselines, and scheduling regular script reviews helps avoid these.
