The quick download
Actionable monitoring starts with separating real performance signals from operational noise.
Production telemetry is flooded with noise from data gaps, autoscaling events, and concept drift, all of which obscure genuine performance issues.
Filtering techniques like Simple Moving Average, Kalman filters, and frequency-domain transforms isolate meaningful trends from noisy time series data.
Defining operational baselines and thresholds turns raw metrics into alerts that drive action, not distraction.
Apply these techniques at scale with AI-powered observability platforms that automate noise reduction across your entire infrastructure.
In IT operations, the signal is the telemetry that indicates something requires attention. Noise is everything else, including normal variance, autoscaling events, holiday traffic patterns, and data collection gaps.
Separating signal from noise is what turns monitoring data into actionable insight. It separates alerts that drive action from those that waste an engineer’s time.
In this article, we’ll examine the most common sources of noise in production monitoring data and the filtering techniques used to extract actionable insights.
What Causes Noise in Production Monitoring Data?
Production environments introduce several data fidelity issues. Some of these include:
- Data collection issues: gaps or errors in how metrics are gathered
- Missing data: incomplete time series that distort trend analysis
- External factors: autoscaling events or traffic shifts that affect metrics without indicating a problem
- Concept drift: changes in the relationship between input and output variables over time, even when inputs appear stable
The following plot shows an observed signal (in blue) with noise and the underlying signal without noise (in red).
Unlike this simplified example, production monitoring data rarely lends itself to visual inspection alone. Given the volume of telemetry generated in modern environments, algorithmic approaches are essential.
What Makes a Monitoring Insight Actionable?
Consider the time series plot below, showing Wait Time over 12 days for healthcare.gov. Performance is strong at night (low Wait Time) and degrades during the day (high Wait Time). That’s informative, but it isn’t actionable because a normal operating baseline hasn’t been defined.
While there are spikes in Wait Time in this example, you first need to define the threshold at which a spike signals a capacity issue. If the upper bound on Wait Time were set at, say, 120 ms, then the data shows multiple instances above that threshold, pointing to potential capacity problems. For operations teams managing infrastructure at scale, this is exactly the kind of insight that drives action.
In the plot below, we can see a gradual increase across all three metrics.
Linear regression detects the consistent upward trend across these metrics, signaling the need to investigate capacity before performance degrades further.
Some insights may be interesting without being immediately actionable. For example, response time data from multiple wireless nodes may show performance degradation that has little to do with the application itself and more to do with saturated mobile networks or other external internet conditions. For operations teams, the value comes from being able to distinguish between issues they can fix directly and issues that originate outside their own infrastructure.
How to Filter Noise from Monitoring Data
Noise reduction in monitoring data draws from the same filtering techniques used in image, audio, and video processing, adapted for time series. A wide variety of filters exist, but they fall into two broad categories:
| Filter type | What it does | Example |
| Low pass | Passes signals below a frequency cutoff, attenuates above it | Simple Moving Average (SMA) |
| High pass | Passes signals above a frequency cutoff, attenuates below it | Used to isolate spikes or rapid changes |
The red line in the plot above is the SMA of the original signal shown in blue. SMA filters out most of the noise and closely approximates the underlying signal shown earlier. Note that, by construction, there’s a lag between SMA and the underlying signal.
Depending on the requirement, either linear filters (such as SMA) or non-linear filters (such as a median filter) can be used.
More advanced filtering techniques are available for environments where simple smoothing isn’t sufficient:
- Kalman filters continuously estimate the true system state from noisy measurements, making them useful for dynamic environments.
- Recursive Least Squares (RLS) and Least Mean Squares (LMS) adapt to changing data over time
- Wiener-Kolmogorov filters estimate an underlying signal when the statistical properties of the noise are known
Noise reduction can also be performed in either the time domain or the frequency domain.
Frequency-domain approaches use transforms such as the Fourier Transform or Wavelet Transform to separate signal from noise before reconstructing a cleaner time series. The appropriate technique depends on the characteristics of the data and the operational problem being solved.
These techniques are effective, but applying them manually across millions of telemetry points isn’t realistic. Modern observability platforms automate this analysis continuously, allowing teams to detect meaningful changes without tuning filters by hand and correlate those changes with operational context across metrics, logs, events, infrastructure, and external dependencies.
Put Signal Processing to Work in Your Environment
LogicMonitor Envision applies AI-powered anomaly detection, adaptive baselines, predictive forecasting, and event correlation across hybrid infrastructure monitoring.
By correlating metrics, logs, and events with operational context, LM Envision reduces alert noise, surfaces probable root causes, and helps operations teams focus on issues that require action.
When performance issues originate beyond your infrastructure, LogicMonitor Synthetics and Internet Performance Monitoring extend visibility across internet paths, ISPs, cloud providers, CDNs, and other external dependencies, helping teams distinguish internet-related issues from problems within their own environment before users are affected.
Together, these capabilities help operations teams spend less time sorting through alert noise and more time resolving the issues that actually affect performance and reliability.
Automate noise reduction across your hybrid infrastructure.
LogicMonitor helps teams reduce alert noise, identify meaningful performance changes, and resolve issues across infrastructure and external dependencies.
What is the difference between a low-pass filter and a high-pass filter in monitoring data?
A low-pass filter smooths data by allowing signals below a frequency cutoff to pass through, removing rapid fluctuations. A high-pass filter does the opposite, isolating spikes and rapid changes by attenuating slow-moving trends. In monitoring, low-pass filters like Simple Moving Average help reveal underlying performance trends, while high-pass filters help detect sudden anomalies.
How do I define an actionable threshold for my monitoring metrics?
Start by establishing a normal operating baseline for each metric using historical data. Then set upper and lower bounds that reflect the point at which performance degradation affects users or capacity. For example, if Wait Time consistently stays below 120 ms during normal operations, breaches above that threshold signal a capacity issue worth investigating.
Can signal processing techniques handle the scale of modern production environments?
Manual application of filtering techniques across millions of telemetry data points is not practical. Modern observability platforms like LM Envision automate these techniques continuously, applying AI-powered anomaly detection, adaptive baselines, and predictive forecasting to surface meaningful changes without requiring manual filter tuning.
Denton Chikura is a Content Marketing Manager for LogicMonitor Digital Experience, where he drives content on observability, Internet performance, and digital experience. He writes for SREs, IT operations teams, and business leaders, turning performance data into guidance they can act on.
