The Complete Guide to Border Gateway Protocol (BGP) Monitoring
BGP is the routing layer that helps hold the internet together, but when something goes wrong, the impact can be fast, confusing, and hard to trace from inside your own network.
This guide gives network teams a practical foundation for understanding how BGP behaves in the real world, including route monitoring, peer health, session states, path selection, route reflectors, multipath routing, LOCAL_PREF, MED, communities, resets, and hijacking risks. Each deep dive connects core BGP concepts to the monitoring signals that matter most, so teams can spot instability earlier, validate routing changes with more confidence, and protect service availability across complex, distributed networks.
Request a demo
See demos and tours
BGP Monitoring Guide
BGP is the protocol that holds the internet together, and when it fails, the impact is global. Learn how effective BGP monitoring keeps your…
Learn the basics
BGP Route Reflector
Full-mesh iBGP doesn’t scale. BGP route reflectors solve that problem by allowing a single router to reflect routes to all iBGP peers without the…
Learn the basics
BGP States
Every BGP session progresses through six states before it’s fully established. Understanding the BGP finite state machine tells you exactly where a session is…
Learn the basics
BGP Multipath
BGP normally installs a single best path to each destination, but BGP multipath changes that. Learn how ECMP and UCMP work in BGP, when…
Learn the basics
BGP Path Selection
BGP doesn’t just pick the fastest path, it follows a strict attribute evaluation order to select the best policy-based route. Learn the full decision…
Learn the basics
BGP Hijacking
BGP has no built-in authentication, which means any AS can announce prefixes it doesn’t own. BGP hijacking exploits this to redirect or intercept internet…
Learn the basics
BGP Reset
A BGP reset tears down a peering session and forces full route table re-exchange, in a large network, that’s a major event. Learn what…
Learn the basics
BGP Troubleshooting Cheat Sheet
BGP session issues can be tricky to diagnose without a systematic approach. This troubleshooting cheat sheet walks through the most common failure categories, from…
Learn the basics
BGP Local Preference
LOCAL_PREF is BGP’s primary tool for controlling outbound traffic within an AS. A higher value means a more preferred path. Here’s how it works,…
Learn the basics
BGP Tunnel Broker
If you have IPv6 prefixes but exist in an IPv4-only part of the internet, a BGP tunnel broker bridges that gap. Learn how tunnel…
Learn the basics
BGP MED Attribute
BGP MED lets you suggest which entry point a neighboring AS should use when sending traffic to you. Learn how it works, when it…
Learn the basics
BGP Attributes
BGP doesn’t just find a path to a destination, it finds the best one based on a rich set of attributes. Learn how each…
Learn the basics
The 8 Most Common BGP Communities
BGP communities are optional route tags that give network engineers fine-grained control over traffic manipulation. This guide covers the 8 most common community types…
Learn the basics
Border Gateway Protocol Routing
BGP routing connects the internet, and operating it safely requires more than just correct configuration. This guide covers the best practices that ensure your…
Learn the basics
BGP Peer
BGP peers are the foundation of internet routing. Learn how BGP peering sessions are established, what to monitor in each session, and the best…
Learn the basics
