The quick download
When AI agents start transacting autonomously, traditional monitoring tools lose visibility at every layer.
Agentic commerce systems like Google’s AP2 span DNS, CDN, origin, microservices, and LLM endpoints, creating failure modes that standard synthetics can’t detect.
Real-world testing revealed hidden Gemini 429 errors wrapped inside 200 OK responses, merchant service timeouts, and CDN origin failures, all invisible to conventional monitoring.
Catchpoint IPM’s synthetic testing, token tracking, and Internet Stack Map correlation pinpointed root causes across the full execution chain, from intent to payment.
Map your agentic stack layer by layer and instrument each hop now, before autonomous transactions scale beyond manual troubleshooting.
In emerging agentic commerce architectures like Google’s AP2, AI agents are executing transactions end to end: searching products, fetching credentials, and initiating payments without a human in the loop. These systems introduce a new class of reliability risk. A transaction can return 200 OK while the LLM silently fails, times out, hallucinates, or stalls inside a downstream agent. Traditional monitoring won’t catch it.
We call this challenge intent execution monitoring: verifying whether a user intent successfully completes across AI reasoning, APIs, infrastructure, and payments. When an agent fails to buy the coffee maker a user requested, the question isn’t just “what broke” but “where in the decision-to-action chain did it break, and why?”
The Technology: How Agentic Commerce Works
Google’s Agentic Payments Protocol (AP2) is one of the first open frameworks designed to enable AI agents to handle end-to-end commerce transactions from product discovery to checkout.
Instead of a human clicking through a shopping cart, an AI agent (powered by Gemini) can:
- Interpret a natural-language intent: “Help me buy a coffee maker from Amazon”
- Search merchant catalogues through APIs
- Fetch user credentials from a secure wallet service
- Initiate and confirm payment, all through machine-to-machine communication
Behind this, a network of microservices, including merchant, payment, and credential agents, coordinates the transaction.
Each agent communicates over JSON-RPC (Remote Procedure Call), using the AP2 spec to ensure trust and interoperability between systems. All agents in AP2 communicate over JSON-RPC and follow the AP2 spec, which ensures consistent trust and interoperability even when agents are built by different teams or deployed in different environments.
This lets a shopping assistant, merchant, and payment provider coordinate securely, even if they’re built by different companies or run in different environments. By enabling coordination across organizations, AP2 shows how AI can now guide and perform commercial transactions.
The Problem: Visibility Collapses When Logic Moves to AI
That new autonomy comes with a price: blind spots. Traditional synthetic tests assume deterministic logic. You click, the app calls an API, and you measure latency and response codes.
But in an agentic architecture:
- The logic is non-deterministic (driven by model reasoning)
- The execution chain spans multiple networks, LLM APIs, merchant systems, CDNs, and payment processors
- Failures are contextual, not just code-based (e.g., “Gemini throttled this request” might look like a 200 OK)
Once AI starts making the decisions, traditional visibility tools can no longer map what’s happening across the full execution chain. The core challenge: how do you monitor a system that decides, learns, and acts dynamically across infrastructure you don’t fully control?
Our Setup: Recreating the Agentic Stack
To answer that question, Catchpoint, a LogicMonitor company, built a functioning AP2 environment using Google’s open-source agentic-commerce/AP2 repository.
The local environment included:
- Frontend: The AP2 Dev UI, hosted behind Cloudflare CDN (simulating public access)
- Origin: A tunnelled environment representing an AWS backend (FastAPI services)
- Backend Agents:
- Merchant Agent — processes shopping queries
- Credentials Provider — stores payment credentials
- Payment Processor — handles mandate creation and transaction flow
- AI Brain: Gemini 2.5 Flash, invoked via Google’s Generative Language API
In short, a complete AI-driven commerce stack, from intent to reasoning to payment initiation, running autonomously. We then used Internet Performance Monitoring to measure performance, track latency, and identify failures across the system.
Monitoring the Agentic Commerce Stack
We modelled the system using Internet Stack Map to visualize and test every layer.
| Layer | What It Represents | Monitoring Method |
| DNS (Cloudflare) | DNS resolution and routing for the domain | DNS Monitor |
| CDN (Cloudflare Edge) | Edge delivery, caching, and TLS | CDN/HTTP Monitor |
| Origin (AWS) | FastAPI service entry point | Web Object Monitor |
| Backend (AP2 Agents) | Merchant, Payment, and Credentials microservices | API Monitors |
| AI Layer (Gemini) | Generative reasoning endpoint | API Monitor with response validation |
| UI (AP2 Dev Interface) | Frontend experience and intent submission | Full Browser Test & Transaction Tests with response validation |
To connect these layers, we used Catchpoint’s global variable extraction to capture the session ID generated in the UI synthetic test and reuse it across multiple backend API tests. Tests ran every 5 minutes from global agents.
The UI synthetic flow traces a user journey from the browser prompt (“Help me buy a coffee maker”) through the multi-agent orchestration, cart creation, payment mandate signing, and final payment receipt. Using Catchpoint synthetic E2E flow testing and Internet Stack Map, we get the following:
Transaction correctness: verifies that intent → cart → payment_mandate → signed_mandate → payment_result flows and that the transaction state is persisted across agents.
Per-service performance: measures response time for each service/agent (create_intent_mandate, find_products, create_cart_mandate, get_payment_methods, create_payment_mandate, sign_mandates_on_user_device, initiate_payment). This converts “who’s slowing down the transaction” from guesswork to data.
In the example below, we see find_products alone took 13 seconds to fetch all product SKUs.
Token consumption visibility: tracks model token usage (prompt, completion, total) per run so you can spot cost anomalies or prompt drift.
Waterfall & Explorer insights: waterfall traces and explorer request/response bodies surface the exact failing/requesting call and payload, enabling fast root cause analysis.
Stack map correlation: connects failing runs to observed infrastructure components (CDN, edge, middleware, origin) to locate the root cause quickly.
Key Blind Spots We Found
End-to-end AI commerce monitoring with Catchpoint IPM surfaced a few real-world failures that would otherwise appear as generic “assistant unresponsive” events.
1. Gemini Errors
When we began testing, the system looked healthy and all endpoints returned 200 OK. But deeper inspection revealed Gemini 429 errors hidden within successful responses.
2. UI Stuck Due to Merchant Service Timeout
- The front-end chat interface froze after create_intent_mandate
- Catchpoint Explorer and Timing breakdown revealed a connection timeout (~10s) while waiting on the merchant agent service
- The delay was isolated at the connect phase, confirming that the issue occurred before payload transfer, likely a temporary connectivity or backend overload condition
- Stack Map correlation showed this hop passing through Cloudflare → Apigee → Merchant microservice, pinpointing the bottleneck to the merchant layer
3. UI Down: 530 Error From Cloudflare
- Synthetic UI tests later reported complete inaccessibility with an HTTP 530 (Origin Error) response
- The error originated at the CDN edge (Cloudflare), meaning requests never reached the origin host
- Catchpoint’s full waterfall and DNS tracing confirmed normal DNS resolution and SSL handshake, isolating the fault to Cloudflare’s route-to-origin link
- Because the 530 surfaced at the UI layer, RUM or browser logs alone would have masked it as “page load failed”
AI assistants are multi-layered systems where a “slow model” isn’t the only possible culprit. By combining synthetic testing, end-to-end performance tracing, and cross-layer correlation, teams can pinpoint exactly which agent or network segment caused a stall, whether it’s a Gemini model delay, a merchant service timeout, or a CDN origin error.
Evolving Observability for AI-Driven Systems
As AI systems begin to transact independently, observability must extend beyond servers and APIs into the logic that drives decisions. With Catchpoint IPM, organizations can monitor AI commerce environments across both the infrastructure and reasoning layers, gaining visibility into the AI’s decision logic, execution path, and failure points.
Agentic systems like AP2 are early prototypes of a broader shift, where applications become autonomous agents orchestrating workflows in real time. When that happens, performance data will no longer be about page loads or API speeds alone. It will be about intent execution: the AI’s ability to fulfil a task successfully across systems.
By unifying LM Envision, Catchpoint IPM, and Edwin AI into one Autonomous IT platform, LogicMonitor extends observability from systems to intelligent decision flows, giving teams the visibility they need to keep AI-driven operations reliable.
Learn More About AI Monitoring
- AI Observability: How to Keep LLMs, RAG, and Agents Reliable
- What Is Agentic Observability?
- AI Observability in One Platform
Monitor every layer of your AI commerce stack before autonomous agents scale beyond visibility.
LogicMonitor and Catchpoint IPM give teams full-stack observability across agentic systems, from LLM reasoning to payment execution. See how it works in your environment.
What makes monitoring AI agents different from monitoring traditional APIs?
AI agents introduce non-deterministic logic driven by model reasoning, meaning the same input can produce different execution paths. Failures can also be contextual, such as a rate-limit error hidden inside a 200 OK response, which standard status-code monitoring would miss entirely.
How does Catchpoint IPM track performance across multi-agent transactions?
Catchpoint IPM uses synthetic end-to-end flow testing combined with global variable extraction to follow a session ID across the full agent chain. Internet Stack Map then correlates each service hop, from DNS to CDN to origin to LLM endpoint, so teams can isolate exactly where latency or failure occurs.
Can you monitor LLM token consumption alongside infrastructure performance?
Yes. Catchpoint IPM captures prompt, completion, and total token counts per run alongside response time and availability metrics. This lets teams detect cost anomalies and prompt drift in the same dashboard they use for infrastructure observability.
