Monitor beyond your network perimeter.
See how LogicMonitor’s synthetic monitoring gives you visibility into IXPs, BGP paths, and internet performance, not just your internal infrastructure.
What is an Internet Exchange Point (IXP)?
An Internet Exchange Point is a physical infrastructure where different ISPs and network operators connect to exchange traffic directly. IXPs reduce latency, lower bandwidth costs, and improve routing efficiency. Performance at these points directly affects user experience.
What is BGP and why is it important for network monitoring?
Border Gateway Protocol (BGP) is the routing protocol that manages how data packets are routed between Autonomous Systems on the internet. Monitoring BGP is important because BGP misconfigurations, leaks, or hijacks can reroute your traffic through unintended paths, causing latency spikes, outages, or security exposure.
What is an Autonomous System (AS)?
An Autonomous System (AS) is a collection of IP networks and routers under the control of a single organization. Each AS has a unique Autonomous System Number (ASN). BGP is used to route traffic between different Autonomous Systems.
How do ISP tiers affect internet performance?
ISPs are organized in tiers: Tier 1 ISPs form the backbone and peer with each other for free; Tier 2 buy transit from Tier 1s; Tier 3 from Tier 2s. Traffic routed through more ISP handoffs typically experiences more latency. Monitoring performance across these tiers helps identify where bottlenecks originate.
