Configure Microsoft Entra ID SCIM to automatically de-provision users from your portal when you remove or unassign them in Microsoft Entra ID. LogicMonitor recommends using a single Microsoft Entra Enterprise Application for both Single Sign-On (SSO) and SCIM.
The Microsoft Entra ID SSO Enterprise Application does not support SCIM. To configure both SSO and SCIM, create a new non-gallery Enterprise Application by following this procedure.
For more information on configuring SSO, see LogicMonitor Microsoft Entra ID SSO in the product documentation and the applicable Microsoft Entra ID documentation.
IDP Partners for SCIM
LogicMonitor supports SCIM integration with the following identity providers:
Requirements for Configuring SCIM
To configure SCIM, you need the following:
  • A LogicMonitor user with the Manage permission for Single Sign-On.
  • Administrator access to your identity provider (IdP).
Configuring SCIM
  1. In LogicMonitor, navigate to Settings > Single Sign On.
  2. On the Single Sign On page, select the Edit icon for the identity provider.
  3. Toggle the Enable SCIM switch.
enable_scim
  1. Select Save IDP.
  2. Select Save.
    LogicMonitor saves the SSO configuration.
  3. On the SCIM tab, select Add SCIM provisioning.
    The provisioning page displays.
add_scim
  1. From the IDP drop-down menu, select the identity provider.
  2. Copy the SCIM Token.
    LogicMonitor generates a SCIM token for the selected identity provider.
    Note: Save the SCIM token in a secure location. You need the token to complete the configuration for your identity provider. If you lose the token, you must generate a new one.
  3. In the Note field, enter a description for the SCIM configuration.
  4. Select Save.
    LogicMonitor saves the SCIM configuration.
Configuring the LogicMonitor Microsoft Entra ID SCIM Integration
  1. Sign in to the Microsoft Entra admin center.
  2. Navigate to Enterprise applications and select + New application.
  3. Select Create your own application.
  4. In the Application name field, enter a descriptive name, such as LogicMonitor SSO and SCIM.
  5. Select Integrate any other application you do not find in the gallery (Non-gallery).
  6. Select Create.
  7. On the Provisioning page, select + New configuration.
  8. In the Admin Credentials section, enter the following information:
    • In the Tenant URL field, enter your LogicMonitor SCIM endpoint URL.
      Example: https://<companyname>.logicmonitor.com/santaba/rest/scim
    • In the Secret Token field, enter the LogicMonitor SCIM bearer token.
  9. Select Test Connection to verify that Microsoft Entra ID can connect to the LogicMonitor SCIM endpoint.
  10. If the connection test succeeds, select Save or Create, depending on your Microsoft Entra ID interface.
  11. On the Provisioning page, expand Mappings, and then select Provision Microsoft Entra ID Users.
  12. In the Target Object Actions section, ensure that Create, Update, and Delete are enabled. Microsoft Entra ID manages user deactivation by updating the SCIM active attribute to false.
  13. Review the attribute mappings.
  14. Remove any default attribute mappings that LogicMonitor does not support to prevent provisioning errors.
  15. Configure the primary identifier mapping.
    • Map the Microsoft Entra ID userPrincipalName attribute to the LogicMonitor SCIM userName attribute.
    • If your SAML configuration uses a different unique identifier, map that same attribute to the SCIM userName attribute so that both SAML and SCIM use the same identity value.
  16. Select Save after completing the attribute mappings.
  17. Navigate to Users and groups.
  18. Select + Add user/group.
  19. Select the users or groups that you want Microsoft Entra ID to provision to LogicMonitor.
  20. Select Assign.
  21. Return to the Provisioning page.
  22. Set Provisioning Status to On. Depending on your Microsoft Entra ID interface, you might need to select Overview, and then select Start provisioning.
  23. Select Save.
Microsoft Entra ID automatically runs a provisioning synchronization cycle approximately every 40 minutes after provisioning is enabled.
If you want to validate the integration immediately, use the Provision on demand feature on the Provisioning page to synchronize a specific user without waiting for the next scheduled synchronization cycle.
